#21 |
![]() ![]() ![]() ![]() Join Date: May 2008
hi pierrot - used to be the same way with cussing . didnt want the church ladies to hear my adjectives and oaths. then i found out church ladies cuss just as badly. so i relearned how to cuss. since you have given me good advice on this forum, i volunteer to give you a refresher course in advanced cussing. wonder if my brake booster will last until 200k. 188k right now. thanks tons bob f
#22 |
Brian90638, click on each snapshot to open a new page for a larger view. A Hall effect sensor is magnetic pickup device to detect metal passing by similar to the crank sensor detecting teeth on crankshafts to generate signals. The metal particles probably aren't enough to corrupt signal generation. The flow chart spells out some simple troubleshooting steps to determine if the sensor is faulty or intermittent.
Snapshots from my '03 L200/L300 manuals. I presume P0343 is a general error code, applicable to all Saturn models. The wiring and flow chart details are specific to L300/LW300 models, presuming they share the same engine and sensor configuration.
VCX NANO |
#23 | |
![]() ![]() ![]() Join Date: Jan 2018
2003 L-Series 3.0L Wagon
![]() Quote:
#24 |
No bother at all. I'm not sure why P0343 continues to pop up and a reason to post service manual descriptions and procedures to determine which way to proceed. The troubleshooting flow chart is very good although anytime the word scantool is included, it means GMs Tech II scantool, not everyone's personal reader. Some imagination is needed to read between the lines when a scantool is needed for say, missing cam position counts.
If this were my problem, I'd use a multimeter to measure for 5v between pins 1 and 3 on the cam sensor connections. If possible, removing the cam sensor and reconnecting it then measuring pin 2 for analog signals (any voltage output) while waving a screwdriver tip past the sensor should display something. A multimeter with a bar graph will show instantaneous signal output faster than the digital display. Testing cam sensor output is rudimentary but may reveal whether or not its outputting when metal is waved past it. Measuring for resistance of the sensor between pins may help too. There shouldn't be any short between pins. The flow chart goes into more details to follow up, before or after measuring sensor supplied voltage and output. This presumes wiring is intact otherwise continuity testing of wiring may be necessary. Examining the ecm dual plugs for loose connections may help since all sensors receive and send signals to it.
VCX NANO |
#25 | |
I'm happy that you've found something useful in my comments here in SaturnFans. Thank you!
![]() ![]() Regardless, as it relates to the power brake booster it's one of the least likely items to ever fail on an automobile. I'm reasonably certain the booster in your car will go for many years to come.
347K miles - Holy canolli! Biden/Harris predictions, '21 -'25: weak economy; weakened military; increased terrorism; an emboldened RED CHINA. I fear that I will be correct. I'd rather be wrong. |
#26 |
hello my good compadre and sage advisor pierrot- as a masta cussa who has trained many, keep in mind that cussing is a very creative activity especially because it clears your sinuses allowing more oxygen to get to your cerebrum making you momentarily smarter. this in turn increases the likelihood of figuring out complicated mechanical repairs to jalopies and washing machines . never underestimate its power. good point about brake boosters. old rule from workng on 60s and 70s cars was if brake pedal got much harder to push to stop it was a tipoff to a shot leaking booster. with the booster stinko you had to use more pressure to stop car since the springs in the system were heavier and stiffer with power braking. my 01 L100 has drum rears and disc fronts. can remember only working on two in 60 years. cant be repaired, have to replace. hope mine passes 200k and still stops the car. looked at the diagram and doubt the control valve in the vacuum line from the manifold is available if that craps out. keep up the good work. bob f
#27 | ||
![]() Quote:
#28 |
hi pierrot- my friend you better be careful about doing an ugly repair appearance on a car. that will seem bohemian enough to deny your admission to your hometowns yacht and country club, but no worries merely driving an ancient model T( aka saturn model L) . the car alone would stop your membership. me? has happened the same way many times even though i slightly improved my language. havent seen that vacuum valve anywhere in the aftermarket either. luckily it hasnt blown yet. have almost given up finding rear coil springs too. luckily they too havent busted yet. did you know power brakes do not stop a car any faster than non power- just easier on the foot pressure. stopping distance is more a function of weight, momentum and tire adhesion. uncle moe used to say, brakes wont stop the car , they stop the wheels. told moe about force vectors and coefficients of friction. you dont want to know how he characterized what i said. feelings were again hurt. thanks tons bob f
Bookmarks |
Tags |
booster, brakes |
2002 LW300 rear brake retaining spring problem | ViperSpeed | L-Series Tech | 1 | 05-11-2014 01:47 AM |
2002 Saturn L200 Sudden Brake Failure | slarson | L-Series General | 29 | 11-30-2011 12:19 AM |
M. Brake Cylinder or Power Boost failure? | APE992 | S-Series Tech | 13 | 10-29-2011 10:21 PM |
Brake Failure in 2002 L200 at 57k | slarson | L-Series Tech | 0 | 08-19-2008 11:22 AM |
Brake failure on 2002 L200 | slarson | General Saturn Discussion | 2 | 08-08-2008 10:30 AM |
