Old 01-10-2021, 08:17 PM   #1
jpsuli
jpsuli is a jewel in the roughjpsuli is a jewel in the roughjpsuli is a jewel in the rough
jpsuli's Avatar
1999 SW2
Default LUK Clutch Master Cylinder now different product?
Recently had an issue with my clutch master cylinder I ordered back in June where the clutch became spongy at the top end, I contacted rockauto and ordered a replacement.
The following is what I had, a LUK part, and similar to the one I got 2 years ago on my 97:
This is what I received in a LUK box:
The original LUK design seems to be of plastic and made in the USA, the new one is made in China and is all metal.
It seems to be a rebranded variant of this product on ebay. I can't find anything that looks the same on RockAuto.
Not sure how I feel about it, the car doesn't have the spongy feeling, but the actuation of the clutch definitely doesn't feel as smooth and has a slight squeak to it.
'97 Saturn SL2 @ 146k (M. swapped) - In storage, awaiting an engine rebuild
'99 Saturn SW2 @ 92k (M. swapped) - Daily Driver
r/Saturn_Cars moderator
jpsuli is offline   Reply With Quote
Old 01-11-2021, 10:39 AM   #2
me.theuser
me.theuser is on a distinguished road
2002 SL1
2001 SL2
Default Re: LUK Clutch Master Cylinder now different product?
TBH I think I like the metal one better (quality control might be questionable)
other than that I doubt there is much difference, I wish they had switched over to metal lines too...
Is that a bleeder I see at the top of your new metal one?
I don't remember there being one on the plastic cylinders..
me.theuser is offline   Reply With Quote
Old 01-11-2021, 02:01 PM   #3
hholbein
1997 SW2
I replaced my clutch master & slave cylinder this summer after too much hot weather squeaking. Mine was a Luk purchased on Amazon, and it looked exactly like the original. Much quieter and shifts better too, although installing it with the ABS system was a royal PITA.
America's trade deficit with China has grown hugely in the past four years.... Oh well.....
Old 01-20-2021, 09:39 PM   #4
SlayZombi
SlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the roughSlayZombi is a jewel in the rough
2001 SL
This is an improvement. I actually had the LUK plastic master cylinder and within the day it wouldn't even let me put the car in gear... junk.
SlayZombi is offline   Reply With Quote
Old 01-25-2021, 06:48 PM   #5
jpsuli
jpsuli's Avatar
1999 SW2
Welp looks like it has the squeaking problem. I thought it was the clutch pedal squeaking against the pivoting point of the rod, but grease didn't assist with that.
https://photos.app.goo.gl/FRDWraK5WtH1wbiW7
Old 02-16-2021, 04:05 PM   #6
jpsuli
jpsuli's Avatar
1999 SW2
Schaeffler has responded to my email regarding the quality:
"According to what I see we only have the plastic hydraulic release system. I would suggest contacting Rock Auto and seeing if they got a wrong part in the box shipped out to you."
I forwarded it to RockAuto who said I should just return it for a full refund, and re-order it if I want another - but they couldn't confirm if this is the new norm for these clutches.
The return reason after the rep sent me that email is 'misboxed', so this may have been a one-off but I am curious as to how it got there (possibly someone returned a cheap unit for the LuK one(?) and I just got the 'unopened' return). Speculation, but glad RockAuto responded quickly and covering all costs for me.
Old 02-20-2021, 11:58 AM   #7
macbox
macbox will become famous soon enough
macbox's Avatar
The one I got from Rock Auto about a year ago that went into my rebuild squeaks, same kind of squeak too. Have not made it a priority to look at it, but if it's not the pivot, it's where the rod goes into the master cylinder. It doesn't have the tan master/slave cylinders, and looked very much like OEM.
"The Twins"
#4, "Betty" 1995 SC2m, 167K, rebuilt engine, rolling project. Garage Queen. Still squeaks and rattles.
#7 "Betsy" 1995 SC2, 142K, Winter Beater.
macbox is offline   Reply With Quote
Old 02-22-2021, 01:23 PM   #8
hholbein
1997 SW2
Well that's annoying! Mine used to squeak when it got >85F. I quieted down my clutch cylinder by injecting Sylglyde into the pushrod/boot on the drivers side of the firewall. Worked for 3 years or so, then the squeak started coming back, so I replaced it. Car shifts better too.
Old 02-24-2021, 11:51 AM   #9
Dbad
Dbad is on a distinguished road
How did you do this injection? Squeeze it from the tube or use some kind of tool?
Dbad is offline   Reply With Quote
Old 02-24-2021, 01:22 PM   #10
hholbein
1997 SW2
I used one of those plastic oral syringes with a 2 inch skinny nozzle to squirt the Sylglide behind the dust seal, then worked the clutch pedal in & out to distribute it around.
It's a bit awkward getting under the dash, but not too bad.
Old 02-25-2021, 04:34 PM   #11
Dbad
Great, thanks for the tip. Mine's not installed yet so I'm thinking of doing this proactively.
Old 03-01-2021, 03:15 AM   #12
jpsuli
jpsuli's Avatar
1999 SW2
Quick update to this, the LUK Amazon unit I got as a replacement is the black plastic-type as you would expect; installed it without any issue and have been operating as normal.
If you get the metal one, I recommend you contact the seller as LUK has confirmed that they are not selling this, at least from the person I was in contact with.
Old 03-01-2021, 07:06 PM   #13
Dbad
Can you link to the Amazon page? I also ordered from Amazon in January and received the metal unit:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 03-04-2021, 04:23 AM   #14
jpsuli
jpsuli's Avatar
1999 SW2
This is the exact unit I purchased.
Old 03-05-2021, 11:12 PM   #15
Dbad
Two different LuK reps told me the units are supposed to be plastic, but I can't help but wonder if LuK corporate didn't source units from China at some point. The first rep responded to me on Amazon and the second one was a guy from Schaeffler's techline who basically had the part pulled from their warehouse, looked at it and said, "Yep, plastic."
I dunno. If it's a fake, it's a good one.
I sent it back today. Hope I did the right thing.
Old 03-12-2021, 09:37 AM   #16
Dbad
Just got notified that Amazon will not post my review in which I quoted the responses from LuK saying that what I received is not their product. So if you buy from Amazon, just know that there is a chance you'll get the Chinese metal version—which may or may not be OK.
clutch master cylinder/slave cylinder recommended replacments help A2Saturn S-Series Tech 5 03-01-2019 12:11 AM
2001 sc2 new clutch master cylinder now no pressure on clutch rotolo64 S-Series Tech 6 10-21-2015 09:10 PM
CLutch master cylinder/slave cylinder azwesjr S-Series Tech 1 12-26-2013 10:26 AM
CLutch master cylinder/slave cylinder removal Tjflow S-Series General 7 02-17-2010 05:43 PM
difference between clutch actuator and clutch master/slave cylinder geartooth94 S-Series Tech 3 06-10-2003 12:36 PM
