Old 09-30-2014, 11:02 PM   #1
Jesse Pinkman
Jesse Pinkman is on a distinguished road
Jesse Pinkman's Avatar
2001 SL2
Default I need the masters of the Saturn's forms assistance. 99 sl2 stuck in 2nd gear
So I was on my way to pick up a buddy of mine and stopped to pay a toll. Suddenly out of nowhere I noticed that there was an extreme amount if play between first and second gear and the shifter was pretty much just sliding between the two. I then proceeded to notice that I was stuck in 2nd gear and is unable to slide across to third or forth. The clutch is working fine because I was able to limp it home in second. Not a fun trip I might add. What on earth could this be? Is this the death of my sl2?
Jesse Pinkman is offline   Reply With Quote
Old 09-30-2014, 11:13 PM   #2
cdxhizors
cdxhizors has a spectacular aura aboutcdxhizors has a spectacular aura about
1999 SW2
2002 L-Series 2.2L Sedan
Default Re: I need the masters of the Saturn's forms assistance. 99 sl2 stuck in 2nd gear
Check your shifter bushings under the center console and check the cables on top of the transmission..something might be bound up or the bushing could fail...very common on s-series 5speeds.
cdxhizors is offline   Reply With Quote
Old 09-30-2014, 11:41 PM   #3
If it is not a bushing at either end of the cables then the shift selector at the transmission is worn out. Get 1 that works from a low mileage car, 1 size fits all 91-02. You should be able to select all gears by manipulating the 2 levers on the transmission. If it is jammed in 2nd then it is toast.
Old 10-01-2014, 12:48 AM   #4
Jesse Pinkman
2001 SL2
Is it a hard fix? I don't have a lift, am I going to need to take it to a shop?
Old 10-01-2014, 02:19 AM   #5
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Nope, just pull the center console tunnel plastic and have a look.
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
colonelhogan44 is offline   Reply With Quote
Old 10-01-2014, 02:30 AM   #6
Ubie
Ubie is on a distinguished road
If it's just a bushing it's a pretty simple fix, just take apart the center console and install a new bushing.. If you've managed to fray or shear the cable it's a little more involved but still manageable. You will need to get under the car if this is the case though.
Ubie is offline   Reply With Quote
Old 10-01-2014, 07:32 AM   #7
Sid
Sid will become famous soon enough
Sid's Avatar
If a shifter bushing has failed, you can temporarily hold the cables with a cable-tie.
http://www.saturnfans.com/photos/sho...hp?photo=53021
96 SW2 5MT, Been paid off for 25 years. :)
Sid is offline   Reply With Quote
Old 10-01-2014, 08:21 AM   #8
jambra1
jambra1 is just really nicejambra1 is just really nicejambra1 is just really nicejambra1 is just really nice
And if you need a new bushing, get this stainless steel one and follow the directions.
http://www.ebay.com/itm/1991-2002-Sa...-/111455651557
Retired July 2018
1999 SC2 - 435,023 miles
1999 SL2 - 196,163 miles
Previous
1996 SC2 and 1999 SL2
jambra1 is offline   Reply With Quote
Old 10-01-2014, 11:07 AM   #9
colonelhogan44
I would recommend the delrin bushing -- much easier and still very solid.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 10-01-2014, 11:33 AM   #10
colonelhogan44
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 10-01-2014, 12:23 PM   #11
Jesse Pinkman
2001 SL2
Ok. I just wanted to take a second and thank everyone who has responded thus far. You've all been a huge help and have probably saved me a ton of money. I really appreciate it.
Back to business though.
I took if the center consol and found out that it was the bushing that had failed. (Awwww yeahhh)
Is this a part I absolutely need to order online or would an auto parts store possibly stock one? Also, is there a way I can jerry rig this for the time being so that I'm not out of a car?
Old 10-01-2014, 12:44 PM   #12
jambra1
At least that's a lot easier to fix than a busted cable. Temporarily, you can use some zip ties to hold the cable end eyelet onto the shifter until you get new parts. Keep some extras in the car just in case. And go easy on shifting in the interim.
On the plus side, you were in second gear. First gear is a killer and I had to get towed since I was 30 miles from home when I split a cable. AAA Plus was a big help that time. Have also done it in third.
Retired July 2018
Previous
Old 10-01-2014, 12:46 PM   #13
Lightly hold the cable loop onto the ball and shrads of bushing with a couple of tie wraps. There are lots of fixes for this that have their cheerleaders. Most are effective to some level or another but this one is the one that seems to function the best if you can follow directions to the letter. http://www.ebay.com/itm/111455651557 Oder it today and you will have it Fri or Sat USPS priority and you get real customer support.
Old 10-01-2014, 12:50 PM   #14
Foment_life
Foment_life is on a distinguished road
Foment_life's Avatar
you can grab this one for toyota wipers that works fine, or this two piece set up that's meant to work for this exact application. The Toyota bushing has a better overall reputation as a longer term solution. Zip ties are apparently a capable short term solution as others have said. I bought the 2 piece dorman and ordered a good delrin bushing online for when the dorman one fails.
1999 Saturn SL2 186K **Daily Driver**
2007 Toyota Matrix XR 1.8L 91k //The Out-of-towner\\
1994 Suzuki Sidekick 185k <<Wife's Go-Kart>>
Foment_life is offline   Reply With Quote
Old 10-01-2014, 01:05 PM   #15
colonelhogan44
I put these delrin busings into all my manual cars before the stock one fails:
http://www.ebay.com/itm/1991-02-Satu...10bd95&vxp=mtr
12 bucks, pop them in and done. Stainless is overkill (and more expensive/more of a pain to install) IMHO.
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Old 10-01-2014, 04:15 PM   #16
For a picture of the zip tie fix, click the link in post 7 that Sid posted.
also, (OldNuc tip) get a bit of powdered motor mica. Put it inside the cable loop and on the bushing, and put some at the transmission end of the cable loops, too. will make it very smooth shifting.
Old 10-02-2014, 04:04 AM   #17
Signmaster
I'm at 7+ years and approximately 45,000 miles using the Toyota wiper bushing. I ordered the Delrin right after putting it in, but decided it's not worth ripping the "temporary" one off, and might put more strain on the end loop of the cable.
Tags
1999, sl2, stuck in gear, transmission
1997 Saturn SL2 stuck in 3rd gear...??? importfanatic66 S-Series Tech 1 01-25-2011 02:00 AM
1997 Saturn SL2 stuck in 3rd gear. Help! importfanatic66 L-Series Tech 1 01-24-2011 08:34 PM
Urgent roadside assistance (help, I'm stuck) AJR L-Series Tech 20 02-23-2009 01:17 PM
96 Saturn SL2 Stuck in 1st gear--Manual greensat1 S-Series Tech 4 11-01-2007 06:28 PM
