#1 |
![]() Join Date: Jun 2002
1993 SC2
I've heard that coolant flows through the intake manifold on the DOHCs, and if that's true, how would I bypass the intake (keeping the intake air cooler, making more power)?
Thanks, Matt
Then: 1993SC2m Now: 1996 Jeep XJ, 2007 Kawasaki Ninja 650 |
#2 |
![]() Join Date: Mar 2000
Yes it does.
Routing around it? That's a secret ![]() Abe |
#3 |
yes coolant flows through the 1.9L dohc intake manifold. go outside, open the hood and take a look and you will see hoses going to and from the coolant reservoir in and out of the intake manifold. perhaps you could disconnect the hoses from the intake side and connect them together in a loop bypassing the intake manifold.
eRic 02sc2 DR SCCA Solo 2001,2002 1st DSP WHRRi 2007,2010 Fun Run 1st DR SCCA 2008 Triathalon 1st PF DR SCCA Solo 2009 2nd ST DR SCCA Solo 2010 1st ST Crutchfield: pkeqe-6j8e3-d2qqe |
#4 |
Nope, coolant flows from the head into the manifold then out to the reservoir and heater core. Although it does flow through the manifold it has its own runner, shared with the hot EGR gasses, too. It'd take some fabrication/welding to reroute those passages.
Bookmarks |
intake manifold. coolant hoses | V9exp | S-Series Tech | 5 | 10-08-2009 04:52 PM |
Coolant line on back of intake manifold? | fetchitfido | S-Series Tech | 6 | 08-10-2009 03:34 PM |
2001 intake manifold leaking coolant? | MiNiMaTiC | S-Series Tech | 2 | 01-10-2008 02:08 PM |
Air Intake and Intake manifold | carl | S-Series Mods | 8 | 03-18-2006 10:04 AM |
WTB: 2000-2002 OE air intake and intake manifold | Tycho | Classifieds | 0 | 03-03-2005 12:52 PM |
