Old 01-25-2011, 12:03 AM   #1
importfanatic66
importfanatic66 is on a distinguished road
Default 1997 Saturn SL2 stuck in 3rd gear...???
I have a 1997 Saturn SL2 manual transmission that won't get out of 3rd gear. The shifter will move freely once clutch is pushed in but the car still stays in 3rd gear. I had a friend take a look at it and stated that it could be the "shifter linkage" that might be wrong with it. Not sure what the exact name is. Anyone have had the same problem or could help me resolve this issue?! Thanks in advance.
importfanatic66 is offline   Reply With Quote
Old 01-25-2011, 02:00 AM   #2
lhheston
lhheston is on a distinguished road
1999 SL1
Default Re: 1997 Saturn SL2 stuck in 3rd gear...???
Search the SL forums for shift bushing, you will get a few hits that point you to the delrin plastic or stainless steel replacement bushing. I bought the delrin one for 2 saturns with your problem. Instructions are included. In the mean time, get some hefty zip ties and zip tie the cable end to the shifter end VERY TIGHTLY and the car will be driveable (be careful the first time you shift into each gear, just in case).
Unfortunately, saturn wants you to buy the whole cable and routing the whole cable is a PITB, plus over 100 more.
Best of luck.
lhheston is offline   Reply With Quote
1997 Saturn SL2 stuck in 3rd gear. Help! importfanatic66 L-Series Tech 1 01-24-2011 08:34 PM
1999 Saturn SL2 - Stuck in 1st gear engrforever S-Series Tech 2 06-26-2009 01:55 PM
96 Saturn SL2 Stuck in 1st gear--Manual greensat1 S-Series Tech 4 11-01-2007 06:28 PM
-3 and I got stuck in 2nd gear :( fetchitfido S-Series Tech 6 01-27-2007 07:02 AM
1997 Saturn SL - RPM's go to zero [0] when in 5th gear Odelay40 S-Series General 19 12-07-2005 10:09 PM
