Old 06-23-2010, 10:15 PM   #1
SBXLI93
SBXLI93 is on a distinguished road
SBXLI93's Avatar
2003 ION-3 Sedan
Default Blocked EGR intake manifold port
I'll make this short....Rebuilt engine in April of this year. Cleaned intake manifold as best I could, but I believe I have developed a blockage in the EGR intake port. I keep getting P0405 codes. Fuel mileage has gone from first tank of 35.88 to a 31.5 and sometimes a 29.3 to 25.5. The ETCS is new and no corrosion on plug wires. Had some corrosion on EGR plug wires and pins, cleaned them as well. Then I started to get a code of P0401: A ckt low voltage. Replaced EGR and within two days same code. Got my money back and replaced with new EGR from autozone #21008421 milege jumped up to 31.5 and then back down to 29. Got code#405 again. Is there a way to unblock the intake passageway from EGR to Intake manifold with out taking off car? And yes Old Nuc I tried your method of removing EGR valve and starting car to blow out build up. Car never went to rev limiter on it's on but did sound like I had no muffler on. And one more thig I did rewire egr plug since one of the connectors was rusted .
1999 SL2 748k miles
engine and tranny rebuilt
36.5 mpg
Now I am ready to go for another 500,000!
SBXLI93 is offline   Reply With Quote
Old 06-24-2010, 12:09 AM   #2
Default Re: Blocked EGR intake manifold port
If it did not rev up your plug/blockage is on the intake side. Go get a chunk of old speedometer cable and remove the EGR and roto-root out the passage into the intake.
If you replaced the connector, exactly how did you do this? Best method is to get a good connector and a chunk of wire from a junker and then solder it into your car. Do not use crimp connectors.
The 401 sounds like the plugged intake side and the 405 is probably a connection issue.
Old 09-22-2012, 01:05 AM   #3
jchu210
jchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the roughjchu210 is a jewel in the rough
jchu210's Avatar
what is roto root?.... do u mean try to push the carbon inside the passage until it gets into the intake mani?
jchu210 is offline   Reply With Quote
Old 09-27-2012, 07:29 PM   #4
jchu210
jchu210's Avatar
also where is the egr port within the intake manfold? i cant to find it even after seafoam did a great job at taking out the black carbon.
a picture or a diagrams out there?
thanks
intake manifold TParrish89 S-Series General 3 03-12-2010 10:25 AM
Manifold pressure port jentzsch23 Ion Mods 3 01-24-2007 03:27 AM
Hi-Temp Seals, Dogmounts, Direct Port Manifold freakerz Classifieds 0 10-02-2005 03:29 PM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
Port Matching Intake Manifold to Throttle Body? Wraith Mods and Performance 9 09-25-2003 11:01 PM
