#1 |
![]() Join Date: Jan 2010
hi all, thanks in advance for your help.
i am changing a motor in a 2002 L100, 2.2 liter, dual overhead cam, automatic. have EVERYthing unhooked, all wiring harnesses, vac/gas lines, starter out, power-steering, AC compressor, motor mount, even the seven bolts holding the block to the transmission housing. still can't get it separated from from the transmission. the motor with move about 1/4-1/2 inch toward the passenger's side (away from transmission) but thats it. any ideas? thanks again, Chris |
#2 |
Does this help?
VCX NANO |
#3 |
did you remove the flywheel to torque converter bolts?
#4 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2005
#5 |
#6 |
I dont recall the bolt count but if you got them all you should be able to take a screwdriver and move the torque converter with the engine flywheel remaining fixed.
#7 | |
![]() Quote:
where is the (item 26 in the instructions provided above) transmission nose bracket? i appreciate the help, from you all. thanks Chris Last edited by chrissat02; 02-27-2010 at 10:09 AM. |
#8 |
Once the converter bolts are removes the converter will turn with a slight nudge.
This step is needed to align the bolt holes when putting the new motor in but can be used to verify the flywheel is seperated from the converter when removing an engine from an automatic transmission.. Based on your inspection of the new motor flywheel, it sounds like this may not be your problem. |
#9 |
sounds like you have something seized together from time and it just needs a little man handling to get it apart.
Rob 2001 Turbo L200 1997 F150 XLT 1985 Range Rover Classic 1999 Yamaha Blaster YFS200 Do It Yourself |
#10 |
If the engine is moving a 1/4 to 1/2 away from the transmission then everything is disconnected. What you are experiencing may be a siezed into the crank converter center noise piece. If the torque converter will not push into the transmission with a push then this is likely the problem.
You need to be able to get the converter away from the flex plate.
A lousy day in paradise is still a day in paradise. |
#11 |
got the motor changed. the trick was to disconnect the transmission nose bracket. where is that you might ask, i know i asked. it is on the bottom front timing chain end of the block sorta between the block and the transmission. has to be removed from underneath and we missed it because we were not working with a lift. once those two bolts were removed the engine just about jumped out of the car.
anyone know where i might post a few parts? thanks again for your help, Chris |
Bookmarks |
Oil Pan Magic Trick?? | wcryle01 | S-Series Tech | 13 | 01-05-2017 09:12 PM |
What's the trick for getting the headliner out of the car? | glueguy | S-Series General | 3 | 07-03-2009 11:09 PM |
Any trick to removing | beedees | L-Series Tech | 2 | 01-05-2009 08:58 PM |
attempting to trick 02 | cadeoradee | S-Series Tech | 3 | 10-13-2008 07:29 AM |
Help with paperclip trick | Pete93SL1M | Miscellaneous Tech | 4 | 12-11-2001 10:59 PM |
