Old 08-10-2009, 12:25 PM   #1
Default Coolant line on back of intake manifold?
If that's what it is, where is the other end of the line supposed to be?
It's not directly part of the PCV valve line, its on the firewall side (opposite of the PCV line on the intake) of the motor and points straight down after ~1inch. I'm pretty sure it's a coolant line, but the lines to the heater core are all connected and the hose that must have been there before has since disappeared.
Old 08-10-2009, 12:29 PM   #2
Squareback
Squareback's Avatar
2005 ION-2 Sedan
Default Re: Coolant line on back of intake manifold?
Sounds like the drain for the Evap to me, but a pic sure would help.
Certified Saturn Technician
Old 08-10-2009, 12:35 PM   #3
No, got that mini line connected too. Just went out to fill the transmission with ATF and the evil missing hose was in the way. It's something to do with the brake booster, probably the vacuum supply for the "power assist." Nothing to do with the coolant after all.
Old 08-10-2009, 12:41 PM   #4
Low Saturn
Low Saturn's Avatar
2007 AURA XR
If you're talikg about the brake booster vacuum line. One end connects to the brake booster, the other on the back/center/upper part of the intake manifold.
It is it disconnected? You have one heck of a vacuum leak.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 08-10-2009, 12:52 PM   #5
mattelderca
mattelderca will become famous soon enough
mattelderca's Avatar
1998 SC1
1996 SL
I'd be pretty surprised if the car would even run with the brake booster line removed. Sure would cause some driveability issues! But that line runs nowhere near the tranny fill ports, auto or manual??
2000 SL1 freebie, my sons DD
1998 SC1 still running, FOR SALE cheap!
1996 SL, GONE but not forgotten
2005 Generic Silver Minivan (Kia Sedona)
2009 Nissan Sentra 2.0S
mattelderca is offline   Reply With Quote
Old 08-10-2009, 12:54 PM   #6
Squareback
Squareback's Avatar
2005 ION-2 Sedan
The car will definitely run with the brake booster line disconnected, though the 4K RPM idle would be a dead giveaway that something is wrong. Again, pics would really be a big help here.....or I guess we could all just keep guessing exactly what you're talking about.
Old 08-10-2009, 03:34 PM   #7
It's all figured out now, it was the bigger line that goes to the brake booster. At the time all I could think of it being was a coolant line but that was wrong.
Engine runs fine, though it sounds like I traded a ticking timing chain for ticking lifters/rockers. Grrr. Has an exhaust leak too as 1 of the bolts broke clean off on the header->downpipe flange, not 100% sure how to get it out, pretty sure the header has to be removed, then the bolt drilled then easy out. It's not happening today though, I'm done
edit: here's a pic includeing my ghetto intake anti-rub pads:
intake manifold. coolant hoses V9exp S-Series Tech 5 10-08-2009 04:52 PM
2001 intake manifold leaking coolant? MiNiMaTiC S-Series Tech 2 01-10-2008 02:08 PM
Air Intake and Intake manifold carl S-Series Mods 8 03-18-2006 10:04 AM
WTB: 2000-2002 OE air intake and intake manifold Tycho Classifieds 0 03-03-2005 12:52 PM
Coolant in Intake Manifold? 1993SC2 Mods and Performance 3 03-11-2003 10:53 AM
