Old 08-02-2020, 01:14 PM   #1
GTSRider
GTSRider is a jewel in the roughGTSRider is a jewel in the roughGTSRider is a jewel in the roughGTSRider is a jewel in the rough
Default 2003 ION Stalls at Stop....Now Dangerous to Drive
I know this has been covered before, but not sure if a cure was ever found.
MY 2003 ION 2.2 is now dangerous to drive. Stalls out at light or stop sign, when you depress gas pedal , or when trying to park .
Engine runs fine in every other way.
Recent Replacements to no avail ....problem persists.
New spark plugs, and Ignition Module
New IAC, and TPS.
Few year old , dealer installed fuel line , and filter
Cleaned Throttle Body, and IAC port
Have not checked codes.... but will try tomorrow
No CEL on dash
Where are the vacuum lines on this 2.2 that should be checked ?
Oh....here is the really strange part....does Not do it all the time,
but noticed yesterday, while doing shopping.... as car sat while shopping,
situation seemed to get worse possibly due to heat soak.
For each shopping stop I would do, it would get worse.
So problem is intermittent, to add to the frustration of solving this problem.
Thanks
Pete
Hudson Valley , N.Y.
GTSRider is offline   Reply With Quote
Old 08-03-2020, 11:57 AM   #2
Default Re: 2003 ION Stalls at Stop....Now Dangerous to Drive
There are several areas to consider - loose/damaged/broken wiring, loose/damaged/broken grounds, original ignition switch fault, intermittent crank sensor. Patience and in-depth troubleshooting might help to determine where fault lies as this seems to be very troublesome, leaving you with an unreliable car.
Was the ignition switch recall performed to rule it out? As you may or may not know, Ions were the first Saturns to incorporate logic voltage (5vdc) in the ignition switch circuitry. Dielectric grease used for corrosion protection hardened in severe cold temperatures, inadvertently disconnecting wiper arms in these ign switches, interrupting the ignition circuits. Killing the engine at random is the result. GM recalled ignition switches.
If the ign switch recall was performed, maybe tapping/wiggling wiring and connections with the engine idling may kill the engine, suggesting damaged/broken wiring at connection points or wires hidden from intact insulation. If electrical mods were made for aftermarket electronics, are they spliced into the ignition system?
Two main grounds; battery negative to chassis and chassis to engine block. Two main battery positive connections; battery to engine block (long red wire from trunk to engine block) and Remote Start Terminal post next to the engine fuse box. The remote start post is used for connecting booster cables on the engine; jumper ground to engine block, positive booster cable connected to the remote start post instead of trunk connections. This remote start post may become loose and interrupt power to the main fuse box and/or starter. Check this post for looseness and corrosion.
The crank sensor is the electronic heart beat of the entire EFI system. It can fail in one of two modes; outright failure or intermittently. Outright failure simply kills the EFI system - engine cranks but never fires up. Intermittent failure tends to be engine heat soaking - as engine heat transfers to it, the sensor fails, interrupting the EFI system, killing the engine. Cooling off, the sensor operates until its warmed up, killing the EFI system. Removing it for bench testing of resistance can help reveal a faulty one. Normal resistance is between 800-1200 ohms in freezing or hot engine running. If resistance increases when dipped in boiling water, the sensor is faulty. The crank sensor provides precise timing signals (electronic clock) to the pcm to operate the EFI system. A faulty or intermittent crank sensor disrupts EFI operation. A steady pulse train of signals are expected from every crank sensor when the engine rotates.
Old 08-19-2020, 03:55 AM   #3
nickson
nickson is on a distinguished road
Might be a fuel pressure issue. Any fault codes?
nickson is offline   Reply With Quote
Old 10-15-2020, 06:33 PM   #4
GTSRider
No Fault codes at all.
Replaced IAC , TPS, Intake temp sensor, and Manifold pressure sensor.
Want to replace MAF sensor, but not sure where it is.
Has anyone replaced a MAF sensor, and can shed some light on R/R of it ?
Old 10-15-2020, 07:01 PM   #5
Ions don't have maf sensors.
Old 10-16-2020, 01:13 AM   #6
ruley73
ruley73's Avatar
The 2003-2004 Ions don't have a MAF sensor. Only the later 2005-2007 Ions which have throttle-by-wire have a MAF (and MAP) sensor.
Does your Ion have a manual or auto transmission? Quad Coupe or sedan?
Does the car drive fine once it's moving?
Does it stall immediately when coming to a stop?
Does the engine have any trouble restarting after it stalls?
Does the engine idle fine while parked or sitting in neutral?
How old is the battery?
Have you had the alternator checked?
GM did issue TSB# 04-06-04-029A to address erratic idle/stalling issues in closed throttle situations. In the TSB, the fix is to have the ECM recalibrated. The PDF of the TSB is too big to attach so I took some screenshots (see attached pics below).
I suppose it's possible, but seems unlikely that your car would still need this update. The issue in the TSB strikes me as a problem that would've most likely been noticed and addressed shortly after the vehicle was purchased. The ECM calibration has probably already been done a long time ago if it was applicable to your Ion.
If the car seems to have an overall loss of power, I'd recommend testing fuel pressure and/or temporarily removing the upstream oxygen sensor to rule out a plugged catalytic converter.
2007 Chevy Equinox LT 200K miles
2018 Chrysler Pacifica Touring L 60K miles
Old 10-16-2020, 07:53 PM   #7
GTSRider
No wonder I could not find the damn MAF ! .....and yet Rock Auto is sending me a MAF for a 2003 ION ! Oh well , sending that back before I even open it....
ruley...it is the 5 speed AISIN, been a great tranny for this 4 door do everything car.
Yes drives like new, other than the problem.
It dies in a parking situation , STOP sign, or RED light.... but ONLY after it reaches peak operating temperature....will NOT do it upon cold starts , and the first 15 minutes of driving. I can only drive it with one foot on brake, one on throttle..... have come real close to having a big pickup truck in my back seat, after light changes GREEN.
Yes , idles fine in neutral or park. Battery is about 4 years old now, alternator replaced 3 years ago....but will check battery.
No never got TSB done, but did have recall ignition done 4 years ago.
No loss of power....power is good for 230,000 miles..... OH ...one thing I forgot to mention....it has the cracked exhaust manifold , with NEW one waiting to be installed... Could the loss of back pressure cause the engine to run too lean , thereby causing the stalling off the line ?
2003 ION stalls at stop sign...otherwise.... GTSRider Ion General 3 08-16-2020 06:53 PM
2002 engine stalls when i stop JHarbison Vue Tech 20 08-05-2013 11:56 AM
Suspect bad diff-pin. dangerous to drive? n2stc S-Series General 2 03-15-2010 12:11 AM
Stalls when idle or come to stop... Aztek_SC2 S-Series General 6 12-10-2007 08:48 PM
93 sw2- stalls at stop once warm ndsaturn S-Series General 2 09-14-2004 03:45 AM
