Old 08-26-2011, 08:12 PM   #1
Maroon97SL
Maroon97SL is on a distinguished road
Maroon97SL's Avatar
2000 SL2
1997 SL1
Default 97 sl1 starting issues
So ever since I bought this Saturn its had starting issues when its warm. It always starts on the third try. The first few tries it acts like its not getting gas, could this be the fuel pump, if so do I have to drop the tank to replace it?
00' SL2 / White / 5-speed / DOHC 213k miles (1000$ cash)
97' SL1 / Burgandy / AUTO / SOHC 160k miles (J/Y engine swap, engine has 101k on it) Back on the road!!
Maroon97SL is offline   Reply With Quote
Old 08-26-2011, 08:24 PM   #2
Default Re: 97 sl1 starting issues
Are you aware of the faulty pump check valve allowing pressure bleed off when the pump stops? Search the posts about '97's and the simple start up procedures.
VCX NANO
Old 08-26-2011, 08:32 PM   #3
Maroon97SL
Maroon97SL's Avatar
2000 SL2
1997 SL1
Like the ten second procedure?
Old 08-26-2011, 10:57 PM   #4
madpogue
1996 SW2
^^^^ +1. Think of it like a diesel. Turn the key to RUN and wait. More like 5 seconds rather than 10. Then hit START.
Old 08-26-2011, 11:02 PM   #5
Maroon97SL
Maroon97SL's Avatar
2000 SL2
1997 SL1
Still won't start till the third try.
Old 08-26-2011, 11:25 PM   #6
off-track
off-track has a spectacular aura aboutoff-track has a spectacular aura aboutoff-track has a spectacular aura about
off-track's Avatar
"Borrow" a FP tester from your FLAPS. It's a REALLY good bet you'll find that the pressure looks good with key on and drops right off with key off. I put up with this crap for a year and finally had ENOUGH. Replaced the pump and it was one of the best things I've done!
Yes, you have to drop the tank. Not a lot of fun in August (when I did mine last year) but, not that big a deal. One strap bolt was a PITA though! ShaunV posted an excellent how-to on the procedure.
1997 - SL2, barebones, 161k, Auto - Rebuild complete and.. burnt a valve 20k later Arrgh!
Purchased 114k 10/07
Added OEM CC
off-track is offline   Reply With Quote
Old 08-26-2011, 11:27 PM   #7
Maroon97SL
Maroon97SL's Avatar
2000 SL2
1997 SL1
How much are fuel pumps for these cars?
Old 08-26-2011, 11:45 PM   #8
off-track
off-track's Avatar
Not cheap. I paid $194 for one but it was well worth it IMHO!
Check rockauto.com and be sure to use the latest "how did you hear about us" code for another 5% off.
Added OEM CC
Starting issues klexmad S-Series Tech 8 06-16-2011 08:00 PM
96 SL1 Starting Issues!! HELP mlight S-Series Tech 5 11-29-2010 10:57 PM
Starting issues 04SilverIonChic Ion Tech 4 11-24-2009 02:50 PM
'94 SC2 Starting Issues 386 SC2 S-Series Tech 8 11-13-2007 11:23 AM
odd starting issues kingvandal S-Series General 8 01-02-2007 04:20 AM
