Old 08-24-2011, 10:01 PM   #1
MKR
MKR is on a distinguished road
1997 SC2
Default Click click crank
I think I just drained the battery by starting too much and using too much power, but it can't hurt to ask.
  1. Drove to get a haircut
  2. Drove 500 feet to Wal-Mart
  3. Drove 2 miles to the grocery store
I also had the fan and AC running at full blast the whole time. It clicked once when I turned the key at the last stop, then clicked again on the second turn. It cranked on the third try.
This was after it sat for 2 days. Is this a symptom of putting too much on the battery without giving it time to charge up?
MKR is offline   Reply With Quote
Old 08-24-2011, 10:50 PM   #2
td1238
td1238 will become famous soon enoughtd1238 will become famous soon enough
Default Re: Click click crank
If it otherwise cranks at normal speed, and your headlights are fully bright with the key 'off,' then the problem likely lies within the starter solenoid. You can merely replace the solenoid (which requires removal of the entire starter motor), or you can replace the entire motor. The brushes are likely worn, too. These are special order from NAPA, and they come from Virginia. The brushes and solenoid are likely much cheaper than a new motor, but might not be as convenient.
If you do rebuild the old motor, be sure to clean up all external connections.
td1238 is offline   Reply With Quote
Old 08-24-2011, 10:52 PM   #3
td1238
Removing the end cap will disclose the condition of the brushes. If they both look like they have plenty of wear left, then you can probably just replace the solenoid and get plenty more miles out of the motor as-is. Perhaps order the brushes now so that they will be handy later. If you by chance agitate or remove the brush holding assembly, be sure to reinsert the phenolic insulators that go between the brushes and the brush tension springs. If these are not put back in place, a direct short will occur through the tensioning springs, and the motor will not work.
Old 08-24-2011, 11:28 PM   #4
MKR
1997 SC2
Would that explain why it occasionally wont start after sitting a couple of days?
Old 08-25-2011, 01:56 AM   #5
Fingolfin
Fingolfin is on a distinguished road
1995 SW2
Could be starter... just as likely you've got a dead alternator that's just not charging the battery. Go to AutoZone or someplace similar to get your battery tested, just to make sure you don't have a bad one.
On the car with the engine off, your battery should be giving 12 to 12.5 volts from the battery posts. With the engine on, it should be in 13.5-14.5 volt territory. if it's lower than that, chances are your alternator is shot. If it's testing as good, then you've got to look at your starter.
Just went through this myself!
Fingolfin is offline   Reply With Quote
Old 08-26-2011, 12:45 PM   #6
MKR
1997 SC2
The lights dimmed a little bit when I turned the car off, but it was barely perceptible. I'm also pretty sure the alternator is fine because I hear something kicking in when I hold the window button down after it's fully open and when I turn the lights on.
well i got a new problem named click-click- click-click- click-click- click sl2solow S-Series General 3 08-13-2010 10:49 PM
Not starting. Single click. Now no click clean93 S-Series Tech 4 12-03-2008 03:02 PM
Click, click, click goes the dash! skid_marque Vue General 11 05-05-2008 10:26 AM
"Click, Click, Beep." What is that? Commando44 S-Series General 15 11-09-2007 04:59 AM
