Old 03-30-2019, 01:42 AM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default Troubleshooting a newly repaired sunroof
I just installed the sunroof doctor kit on my 2001 SC2 sunroof. I replaced both guides and the motor bracket with new ones, and the cables with junkyard cables which appeared to be in good condition.
Everything worked fine for a couple days. It opened and closed smoothly many times. But then it stopped opening all the way. It gets about halfway to the vented position, then buzzes and stops. It closes again smoothly.
What might have caused it to stop working? What should I look for?
TwoFistedJustic is offline   Reply With Quote
Old 03-30-2019, 06:51 AM   #2
trottida
trottida's Avatar
Default Re: Troubleshooting a newly repaired sunroof
That sounds like a sunroof motor issue. The gears in it are failing.
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
trottida is online now   Reply With Quote
Old 03-30-2019, 10:49 AM   #3
Either the plastic gear on the motor is failing or the cables have a worn out spot in them. If you're careful you can pull the motor out via the map lights without pulling the headliner.
Old 03-30-2019, 05:14 PM   #4
TwoFistedJustic
I think you guys might be right. I took the glass off and the mechanism worked perfectly.
Old 03-30-2019, 05:21 PM   #5
TwoFistedJustic
Is the sunroof motor serviceable?
Old 03-30-2019, 06:02 PM   #6
TwoFistedJustic
I have it working again (for now). When I put it together, instead of the gooey lithium grease provided by sunroof doctor, I used a "dry" RV window track lubricant. That may very well have been the source of my problem. It worked for 48 hours or so then didn't. I relubed with the lithium grease, and then the mechanism worked with the glass installed.
It may also be that just taking the glass off and running the mechanism through a few cycles got it past the worn portion of the gear, and before much time passes, I'll have the same problem again.
Anyone know of a place that rebuilds small electric motors? (just in case?)
Tags
sunroof, sunroof doctor
Me and my newly running SW2 SpaceVagon Introductions & Greetings 4 09-11-2016 12:18 AM
Newly acquied 2000 LS1 ag_ghost Introductions & Greetings 0 02-13-2011 12:33 PM
Questions on my newly purchased Vue scott2683 Vue General 10 01-13-2009 09:50 AM
Troubleshooting shorted lighter, dead sunroof flyvholm S-Series Tech 0 10-17-2006 04:49 AM
Sunroof repaired! bender S-Series General 5 02-07-2006 02:17 PM
