Old 02-16-2019, 06:19 PM   #1
Lovemyredline
Lovemyredline is on a distinguished road
2004 VUE 3.5L
Default Front brake hose blocked
Caliper was dragging on Front brake and creating excessive heat, so replaced caliper, rotors and pads thinking problem solved. Issue continued so ran across a few articles on blocked hoses at the metal bracket that bolts to the strut. Sure enough mine was blocked due to rust from the metal bracket. Just an FYI to check if brakes are dragging.
Thanks
Kevin
File Type: jpeg 5C46C2E8-8C97-413C-9DA8-0AFEB73E21E3.jpeg (107.4 KB, 19 views)
File Type: jpeg 880C710A-2C03-4FCC-BB4A-FB655D804DFF.jpeg (125.6 KB, 16 views)
Lovemyredline is offline   Reply With Quote
Old 02-16-2019, 09:08 PM   #2
KCW
KCW is on a distinguished road
2004 VUE 2.2L
Default Re: Front brake hose blocked
I had to replace a front brake hose on my Vue for the same reason
the inner hose can collapse and act like a check valve - fluid goes in, and does not come back out.
On my normal commute with a manual transmission there are several places where I usually have to stop for a red light, on a slight incline. That is my dragging brake test location - if I hold the clutch in with no brake, the vehicle should creep backwards slightly.
If it doesnt then I know a brake is dragging. You can do the same test with an automatic, drop it into neutral and take your foot off the brake.
KCW is offline   Reply With Quote
Tags
brakes, caliper
brake hose to brake line union? slugbug S-Series Tech 3 06-25-2018 11:27 PM
brake hose replacement saturnsctwo S-Series Tech 12 02-14-2017 08:29 PM
95 sl1 rubber brake hose where to buy? whoodiestyle S-Series Tech 2 03-07-2016 12:33 AM
Need help removing front pass brake hose turbobuick33 S-Series Tech 1 05-06-2007 12:25 PM
Brake Hose, NEED HELP! RalliArt16 S-Series Tech 27 10-12-2005 12:53 PM
