Old 08-17-2017, 04:52 PM   #1
brackstonj
brackstonj is on a distinguished road
Default Discontinued 2002 L300 Engine Hose
I am having a lot of trouble finding this hose. I have found results online using the GM Part Number: 9128535 Engine Crankcase Ventilation Hose (see images for a better idea of what it is). There is also another number on the hose 0066501. Not sure if I am searching for it correctlly.
I am wondering if anyone out there has any ideas for repurposing a similar hose. The biggest problem is it has a ~75 bend. So finding one similar may be difficult.
Internal diameter is 1.5 cm while the total diameter is 2.3 cm.
I have searched the forums here and tried several online parts places from other posts. Tried a GM dealer and have been told that it is discontinued. I have a few more e-mails out there waiting for a response - so there is hope.
I am thinking I will have to just find a similar looking hose and make it fit with clamps. Anybody have suggestions for what type of material to look for? Anybody know off hand of a hose that is usually in stock that is close to this one? I am worried about using the wrong kind and it collapsing.
brackstonj is offline   Reply With Quote
Old 08-17-2017, 05:01 PM   #2
Claybury
Claybury will become famous soon enough
Claybury's Avatar
Default Re: Discontinued 2002 L300 Engine Hose
Funny, I was looking at the same hose last night and thinking it needs to be replaced. Someone had taken a pliers to it and tore it up.
If you have a local parts store, with a clerk who gives a damn, you can take the hose in and ask them to check it against hoses they have in stock of the same diameter. I have had good luck in the past finding hoses that, with some trimming, can work in a pinch.
Offhand maybe a '90's Cavalier/Sunfire bypass hose?
2002 SC2 1.9L
2007 Vue 3.5L
1985 Fiero SE 3.1L
1974 Triumph Spitfire 3.1L V6
2002 Ram duelly diesel 5.9L
1975 Honda PA50 0.05L (Swarm and destroy)
Claybury is offline   Reply With Quote
Old 08-17-2017, 08:51 PM   #3
02 LW300
02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold02 LW300 is a splendid one to behold
02 LW300's Avatar
2002 L-Series 2.2L Sedan
You might look at a pcv hose for a mid 90s Chrysler Concord. That is a little over 1/2"id and has a useable bend similar to what you posted.
2002 L200/5 loaded, coming attractions B207R and F40, Ion Redline axles will make this work.
Old 08-19-2017, 10:02 AM   #4
soulsurvives
soulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to allsoulsurvives is a name known to all
I would either get one from a junkyard or use a generic one. Should not be hard to find something.
soulsurvives is offline   Reply With Quote
Old 08-19-2017, 10:39 AM   #5
billysvue
Especially if you can get back behind the counter at a FLAPS
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 08-19-2017, 01:33 PM   #6
Russet
Russet has a spectacular aura aboutRusset has a spectacular aura about
2002 L-Series 3.0L Sedan
So did you got to your local auto parts store rather then just online and GM dealer? GM Dealer are last resort but jk will most likely have that part but unless a local parts store can't find it then it really is truly gone and a jk is your only choice.
Tags
2002, discontinued, hose, l300
Discontinued Refrigerant Hose? HybridizedVue Vue Green Line 2 06-14-2016 03:25 AM
Heater core hose repair L200 L300 SL2 (possibly others) Solion L-Series Tech 14 07-20-2015 04:29 PM
2001 L300 Heater Core/Hose Leak aalegrete L-Series Tech 49 02-15-2015 08:10 PM
2001 L300 Brake Booster Vacuum Hose ?? phatboy L-Series General 7 01-25-2015 05:33 PM
Engine coolant leak 2002 L300 BigDaddyGuns L-Series Tech 3 11-14-2011 10:42 AM
