Old 04-03-2017, 12:19 AM   #1
MrTwitchyMckat
MrTwitchyMckat has a spectacular aura aboutMrTwitchyMckat has a spectacular aura aboutMrTwitchyMckat has a spectacular aura about
Default Rapid knocking noise when clutch pedal is pressed in?
Hi folks!
A few weeks back I bought my first Saturn, specifically a 1995 Saturn SC2, for a whopping $50. Engine sounded healthy, but it needed a new clutch. I just finished doing the clutch job last night and started her up. It made this terrible knocking noise. It sounded somewhat like rod knock, but I figured out that when I let go of the clutch pedal it goes away. I've looked into it and I've narrowed it down to the throw out bearing which I replaced, and or the pilot bearing which I didn't replace since it didn't come in the kit. I should mention at this point that I've never done a clutch job, but from what I could tell nothing really went wrong.
Do any of you fine people have any suggestions on which it could be? Or am I going in the completely wrong direction. If needed I could upload a video of what it sounds like.
Thank you all in advance!
Add to MrTwitchyMckat's Reputation
Rate the quality of this post and help MrTwitchyMckat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
MrTwitchyMckat is offline   Reply With Quote
Old 04-03-2017, 03:08 PM   #2
BV22
2002 SC1
Default Re: Rapid knocking noise when clutch pedal is pressed in?
I've heard that horrible noise before on another car - it was the throwout bearing. What brand of clutch kit did you use? Luk is the only one that seems to work right in these cars.
BV22
2002 SC1 5M
RIP Sept 1 2018
315,344 miles
Add to BV22's Reputation
Old 04-04-2017, 10:20 PM   #3
TomM96
I don't have much clutch experience; none with Saturn.
If you open it up again, maybe check the crankshaft 'end-float' , the axial movement of the crank into//out of the crankcase....
Add to TomM96's Reputation
Old 04-05-2017, 11:49 PM   #4
MrTwitchyMckat
I just used the generic Autozone Duralast clutch kit that is apparently supposed to fit on my car specifically. I'm not looking forward to pulling off the transmission again
I had a feeling it was that cause I do remember when I put it on it felt super loose.
But thanks!
Old 04-05-2017, 11:50 PM   #5
MrTwitchyMckat
Hmm, okay! I'll have to look more into that cause I'm not 100% sure what that is. I'm wondering if it might also just be the pilot bearing?
Thanks!
New clutch kit and tranny, but still clicking noise from clutch unless pressed nulaw99 Vue Red Line 4 10-11-2012 11:41 AM
Clutch repaired and replaced, now still have a knocking noise Crzesk8dad S-Series Tech 9 01-04-2012 03:17 AM
Noise from Right rear speaker when brake pedal is pressed ncbear52 Ion General 1 08-19-2011 05:28 PM
Clutch pedal squeaking and trunk latch knocking tallNewfie Astra Tech 4 01-09-2010 11:34 PM
knocking noise when clutch is released? gm7 Ion General 7 01-19-2004 01:26 AM
