Old 06-04-2016, 06:12 PM   #1
slimslatty
slimslatty is on a distinguished road
Dizzy wont crank when hot unless jumped
My saturn l300 v6 wont crank when it gets warmed up in the summer. After you let it cool down for about 15 minutes or longer it will crank and start just fine. I have tried two batteries and have cleaned connections. This seems like a typical starter failure except for the the fact that it can be jumped. i know a battery reads 12.5 and a running engine reads about 14. could those extra amps be enough extra power to make the dying starter work?
slimslatty is offline   Reply With Quote
Old 06-04-2016, 06:20 PM   #2
billysvue
Default Re: wont crank when hot unless jumped
Does yours??
Cleaned the connections@ the batt posts?
@ the starter?
Alt puts out what V?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 06-04-2016, 08:31 PM   #3
pierrot
pierrot's Avatar
Welcome to SaturnFans!!
This type of starting issue is always about working from the simple to the complex. The first thing you should have verified is the condition of the battery. If it is weakening and can no longer hold an adequate load required for starting a car then the battery must be replaced. If the same starting issue exists with a known, confirmed good battery and your connections are clean then it is most likely that the starter is failing. Alternator output has little to no effect on the operation of the starter itself. It is possible for a jump start to assist when a starter is going bad, but that situation will not long endure. Eventually, a jump start will not overcome the additional resistance within the starter.
338,000 miles - Holy canolli!
Joe Biden for POTUS and Kamala Harris for VEEP. What follows if they get their way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
Tags
battery, l300, saturn, starter, wont crank
hi im new..got a 01 sl1 that wont crank over joseywales S-Series Tech 14 12-23-2013 04:04 PM
98 SL2 wont crank!! SL2nf150 S-Series Tech 11 08-12-2013 08:02 PM
wont crank please advise matteromysaturn S-Series General 7 06-13-2011 06:06 PM
97 sc dohc- getting gas & spark, wont crank without ether, wont stay cranked after??? P.Johnston85 S-Series Tech 37 06-07-2010 06:29 PM
wont crank Marbar6987 S-Series Tech 1 06-17-2009 02:19 AM
