Old 03-10-2019, 12:40 AM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default S-Series Sunroof Swap
Will a gen3 SL2 sunroof fit a gen3 SC2?
Add to TwoFistedJustic's Reputation
Rate the quality of this post and help TwoFistedJustic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TwoFistedJustic is online now   Reply With Quote
Old 03-10-2019, 10:36 AM   #2
macbox
macbox will become famous soon enough
macbox's Avatar
1997 SC2
Default Re: S-Series Sunroof Swap
No, they are different sizes. If you look on gmpartsgiant, it will ask you which model you have. Being you are in CA you might be able to find what you need in a junkyard.
"The Twins"
#4, "Betty" 1995 SC2m, 163K, 400 Miles per quart. Garage queen. Currently in 1000 pieces for a rebuild.
#7 "Betsy" 1995 SC2, 131K, daily driver.
Add to macbox's Reputation
Rate the quality of this post and help macbox reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
macbox is offline   Reply With Quote
Old 03-11-2019, 02:56 PM   #3
TwoFistedJustic
Thank you for the website to refer to. It looks like they are the same sunroof. All the part numbers match. Even the glass looks the same for all models from 1996 to 2002.
https://www.gmpartsgiant.com/parts/s...~21306024.html
Old 03-11-2019, 09:05 PM   #4
Zeebins
Zeebins's Avatar
91-95 sedans and 91-96 coupes had different size sunroofs. 96-02 sedans and 97-02 coupes shared a sunroof size.
Professional at finding random rattles
1997 SL2, 115K miles
Add to Zeebins's Reputation
Zeebins is online now   Reply With Quote
Old 03-13-2019, 04:29 PM   #5
TwoFistedJustic
I pulled a 02 sedan sunroof out of junkyard.
I can confirm that the glass between the 02 coupe and 02 sedan is compatible.
The metal framework module is not. The sedan module is longer. However, if you just need parts, all the parts except for the lengthwise structural members appear to be the same.
I was just talking to Rick at the Sunroof Doctor and he told me that if you want to swap out the arms, you need to drill out the pop rivets holding the rear cross member waterway and slide the arms out the rear of the sunroof module. To do this you need a 5/32 drill bit to drill out the old rivets, replacement pop rivets, and a pop rivet gun for installation.
To do this you need to remove the sunroof module from the car.
Handy Tip for Removing the Headliner:
Be aware that there are strong velcro patches holding up the headliner. They are stronger than the paper mache that the headliner is made out of. So you need to slide a plastic scraper or plastic prybar between the two sides of the velcro to detach them. If you just pull on the headliner, the headliner itself will rip away from the velcro, leaving the velcro attached to the metal roof of the car.
The velcro patches on the coupe surround the sunroof opening. Whereas on the sedan, they are around the outside of the headliner.
95 S series sunroof will not close all the way doyen58 General Saturn Discussion 1 05-03-2008 09:14 AM
S-series Vs. ION Sunroof darnell89 General Saturn Discussion 0 02-07-2008 04:36 PM
sunroof swap kaseyskar S-Series General 1 10-05-2006 12:32 PM
Roof Swap For Sunroof??? BigMatt101 S-Series Tech 5 04-13-2006 11:30 AM
Sunroof assembly swap and install 98greenSC2 S-Series General 2 09-21-2004 08:44 PM
