Old 04-09-2018, 05:29 PM   #1
TheFlounder
TheFlounder is on a distinguished road
Default LED light issues
Hi all,
I own a 2008 Astra XR and so far every single time I have tried to change a light bulb out for an LED it has failed. The first time was the headlights. While one headlight would work fine, the other would turn on for roughly 30 seconds and then shut off. A little over a year later now I have decided to try the same thing with my interior lights not thinking anything of it. However, when I changed the light in the hatch to an LED bulb it flickers for about 2 seconds before shutting off. Is there something about the wiring of these cars that prevents any sort of change from incandescent to LED or am I stupid? Or Both?
Any replies are appreciated.
Thank you.
Add to TheFlounder's Reputation
Rate the quality of this post and help TheFlounder reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
TheFlounder is offline   Reply With Quote
Old 04-09-2018, 06:16 PM   #2
AstraFasta
Default Re: LED light issues
Do a search for canbus and you will see that replacing bulbs with LEDs in the Astra sometimes requires a bit of magic.
Old 04-12-2018, 12:42 PM   #3
TheFlounder
Ok cool so I just need to purchase canbus LEDs voila?
Old 04-12-2018, 07:54 PM   #4
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
All interior bulbs need to be Canbus friendly, the rear interior lights are very sensitive as in only one wire per side should make contact in the socket (you may need to tape off the other one on some bulbs)
Exterior lights will need a resistor to keep the computer happy. The bulbs turn off because the canbus system shuts power off when it notices a bulb is burnt (or not sending enough resistance through the circuit) which is where a resistor is required to fool the computer.
I'd suggest going with a Canbus HID kit for the headlights if you want more output since LED have a horrible beam pattern in Halogen headlights.
If you have anymore questions let me know. I've replaced everything on my car
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Add to nicolas_p's Reputation
Old 04-14-2018, 03:02 PM   #5
TheFlounder
Thank you very much
Old 04-17-2018, 04:12 PM   #6
TheFlounder
Hi all,
So I've done some research and spoken to some other people in the aftermarket headlight industry. It appears as though what you really need is Pulse Width Modulation (PWM) integration for LED/HID headlights. CANBUS is essentially a whole computer system whereas PWM is what actually affects the lights. With PWM, the electrical signal to the light bulb is sent in pulses. With an incandescent bulb, this means that you save energy and the life of the bulb but the filament doesn't have enough time to cool down so the perceived illumination stays the same. This same thing does not work with LED/HID bulbs and so thus they are incompatible without a mediator of sorts.
I was told that these will solve my issue:
headlightrevolution.com/gtr-lighting-pwm-interface-module-9005-9006-style-connectors
If anyone knows differently or has some other insight I would be very happy to hear it. In the meantime, I think I'm going to give these a try and hope the integration works.
Thanks.
Old 04-17-2018, 05:55 PM   #7
Many cars trucks and SUVs have electronics almost requiring a degree in electrical/electronics technology. Most dealers have to employ not just experienced mechanics but people with electrical and electronics familiarity since most EFI systems, xmissions, climate control, and lighting systems are under control of ECMs, PCMs, body control module or xmission control module (TCM). And let's not forget a separate vcim for OnStar. If you see a pattern, electronics is at the heart of most vehicle systems.
I wired a pair of led dome lights for more trunk lighting. Tapped off the single trunk light, I had to be careful of led polarity. Reverse wiring simply won't allow LEDs to turn on. Since my car uses the bcm, it powers the trunk light for twenty minutes then turns it off for energy savings. My guess is low current circuits can be driven directly from the bcm. Low and high beams draw several amps and require some sophistication of electronics. Whether using pwm or not, circuits are designed to monitor them for burned out bulbs, shorts or normal operation. Canbus and pwm are only two ways of circuit design.
Unless you become informed, led headlights are not great if using aftermarket setups. Factory led headlights are segmented, individual LEDs aimed a few degrees from each other as they have narrow beam patterns. Examine factory led headlights when you can to see why aftermarket led headlights aren't as advertised. I modded my low beams for hid lights only because my low beams are projector light housings that can work with hid lights. The original setup is halogen. Even the place I bought the hid lights couldn't help with set-up. In the end, my lighting didn't need resistors, capacitors or relays. Just plug n' play. My low beams are also DRLs and presented another problem no one was able to help me with. As I did my research, each application is different from the next. My issues were simple compared to others requiring extra wiring. Unless you find the exact same mood done by others with or without extra wiring, you become the beta tester for mods.
Old 04-17-2018, 10:41 PM   #8
FreedomSoftware
FreedomSoftware will become famous soon enough
2008 Astra XR
I got LED headlights from sirius LEDs and they work fine (thought they didnt fit well) but there are sometimes when a notification on the dash tells me to check my low beams. Usually jut flipping the switch for the lights fixes the issues.
'08 Saturn Astra
-Debadge
-Vauxhall Grille
-Thule Roof Rack (and wind fairing)
-1.25" Lowered
-Windows Tint all around
-JVC Head unit
-Dual 12" Subs
Add to FreedomSoftware's Reputation
Rate the quality of this post and help FreedomSoftware reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
FreedomSoftware is offline   Reply With Quote
Old 04-18-2018, 05:19 PM   #9
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
I've had HID with canbus module for 6 years now wired directly into the oem plug with no issue. I have no extra power cables going to the battery to power my ballasts.
Yes our cars have PWM controlled headlights but with the correct product it won't affect anything. My headlights do not dim during the day time and are always on full power with the HID which does shorten their life expectancy with that I'm still getting 2 years on bulbs and 5.5 years on my ballasts
Light issues. adventureoflink S-Series Tech 4 09-25-2009 01:55 PM
ABS Light / Battery Light Stays ON + starter issues 97 SL1 IanDorety S-Series General 3 08-25-2009 11:08 PM
Dome light issues milnimi S-Series Tech 5 02-17-2007 01:06 AM
97 SC2 with issues, chk engine light on, help please dragon370 S-Series General 9 08-17-2006 01:13 AM
Fog light issues SaturnBaby2 S-Series General 1 10-02-2004 07:10 PM
