Old 04-22-2016, 12:19 PM   #1
steven945
steven945 is on a distinguished road
Default 2002 L300 V6 BCM replacement programming issue with Tech 2
I have a 2002 L300 V6
The BCM seems to be failing (very fast odometer accumulation), so I was going to replace it.
I have a Tech 2/TIS2000 setup. I am able to reprogram both my ECM and current BCM with this setup without any issue.
The number on the outside of my BCM is 22697780 and I purchased what was stated as the replacement with number 19116649. The current calibration of the old BCM is 22713289.
I use the TIS2000 and Tech 2 in passthrough mode to replace/reprogram.
When it begins to transfer the data, it gets to the first block, then issues the error "Reprogramming Error! Class 2 - Block transfer data checksum error at step 07." I attempt to retry a number of times, then cancel. I've retried the entire process a number of times, and it always is the same and gives the same error.
Any ideas on this error and how to get past it?
I've attempted to program two of these new BCMs with the same results.
I can either leave the old one in until prompted by TIS2000 to change it to the new one, or just put the new one in before starting the replace/reprogram. In the first case, it pulls the old mileage and in the second case, I enter the new mileage. Same results either way.
I'm willing to try benchtop programming this, so I attempted to make a wiring harness that takes the K-line data from the ODB2 of the tech ii to the BCM class 2 serial data and apply +12V to the battery and ignition on pins and gnd to the gnd... but this doesn't work (TIS2000 gives an unable to connect to device error and the tech2 screen stops moving, showing the data transfer line and symbol). Anyone know how to wire the BCM for standalone benchtop programming (OBPA with a Tech 2)?
Thanks,
Steve
steven945 is offline   Reply With Quote
Old 04-22-2016, 03:15 PM   #2
Default Re: 2002 L300 V6 BCM replacement programming issue with Tech 2
Steve, you're asking questions that are either above the skills and knowledge of most (it not all here (including me) with the exception of maybe less than a handful of former Saturn techs that reply once in awhile. I've never seen a Tech II scan tool other than finding images from a search. All my knowledge is from service manuals and reading in-between the lines. My contributions here would be more questions than answers.
Does a Tech II need to be connected to TIS web to allow programming while it checks for updates? As you know, older GM electronics didn't have canbus with serial communications the only way to diagnose and program pcm's. With ecm's, bcm's, tcm's, vcim's, hvac, abs and airbag modules communicating via canbus with bcm's having serial and canbus wiring, does a Tech II program thru canbus? I don't know if GM has bench setups for programming modules and the few Saturn techs here have never mentioned it. My guess is that it's a little more complicated than you may have guessed.
bcm, harness, l300, obpa, replace
2002 L300 Mind Boggling Sunroof Issue Brad Mac Guy L-Series General 4 03-11-2016 07:25 PM
2002 L300 -- Intermittent Starting Issue jessdykstra L-Series Tech 4 07-27-2013 02:34 PM
2002 L300, weird idle issue FarmerOak L-Series Tech 2 11-04-2012 03:30 PM
2002 L300, Timing belt issue at 40k miles Urbanrover L-Series Tech 5 03-27-2011 12:26 PM
02 SC2 Keyless Programming GM Tech II Firehawk_1989 S-Series Tech 5 07-30-2007 08:25 AM
