Old 01-15-2015, 02:35 PM   #1
werecowmoo
werecowmoo is on a distinguished road
Dizzy Battery Light Troubleshooting
Hello! Forgive me if this should be in the Tech forum, but I hope I can get some insight here...
My battery light just came on and I have no idea why. I checked to make sure I didn't have any lights on when the car was off, and I had the battery was replaced beginning of December. Also, the alternator was replaced right before Christmas. Spark plugs were replaced right before New Years. When I put the accessory belt back on the car it looked to be in pretty good shape but I haven't checked it make sure it hasn't slipped off (its pouring outside).
IF the accessory belt is still on the car, where else should I check? What are the chances of a battery or an alternator failing after a month or less? Could the spark plug change play into it?
Thanks!
Quick Edit: 5 spd manual 1999 Saturn SL.
Add to werecowmoo's Reputation
Rate the quality of this post and help werecowmoo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
werecowmoo is offline   Reply With Quote
Old 01-15-2015, 02:46 PM   #2
2NDSOUT
2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice2NDSOUT is just really nice
2NDSOUT's Avatar
1994 SL2
1999 SL
Default Re: Battery Light Troubleshooting
Whereabouts are you located? Esp. with the colder conditions around the country, it is not completely out of the question that the battery could have developed a bad cell in it.
Take a voltmeter to the battery and see if you are getting 12 Volts with the car sitting and parked. If it is reading 12 Volts, the battery is good. Less then 12 Volts tells you that the battery needs to replaced. With the car started and running, test the battery again with the Voltmeter. If the Battery tests at 13-14 Volts then your alternator is working properly. If it is less, then the alternator will need to be replaced.
Do you have any aftermarket electronics on this car? An aftermarket radio or lighting could cause a parasitic draw on the battery.
Bryan
94SL2 HCE, "Pearl"
99 SL
94SL2 260K Miles
1/15
97SW2 266K Miles
2/15
Always
94SC1 340,501 Miles
Org. Engine/Auto Trans
2/97-10/08
Gone 3/12
92SL1
05VUE
91SC
Add to 2NDSOUT's Reputation
Old 01-15-2015, 02:54 PM   #3
werecowmoo
Bryan,
Battery is less than 1 month old.
Alternator is less than 1 month old.
Located in GA.
Aftermarket stereo which is 1-yr old.
1999 Saturn SL
5-SP Manual.
Old 01-15-2015, 04:17 PM   #4
underthehood
underthehood's Avatar
A dead cell in the battery or just about any other issue battery ONLY related will not make the light come on. It WILL come on because of an issue with the charging system. Start there. Simple things like the belt and check fuses. But odds are your "new" alternator failed
Old 01-15-2015, 08:52 PM   #5
New battery, new alternator? Did you check the condition of the drive belt and tensioner? A worn out belt tensioner not keeping the drive belt taut will simply allow less engine power to transmit from belt to alternator. A slipping belt means less alternator power output to supply power to the car while recharging the battery. If you can depress the drive belt easily with just your fingers, the belt tensioner may be worn out.
Old 01-18-2015, 07:29 AM   #6
bobbyrae
bobbyrae has a spectacular aura aboutbobbyrae has a spectacular aura about
1993 SL2
Is the battery light on all the time or just at idle? Could you give more details?
Bobby Rae
Alameda, CA
1993 SL2 A/T, 80k miles, 22/33/43 mpg
1982 Accord 5-speed, 303k miles, 23/32/40 mpg
Add to bobbyrae's Reputation
Rate the quality of this post and help bobbyrae reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobbyrae is offline   Reply With Quote
Old 01-18-2015, 06:46 PM   #7
boatmoter
boatmoter is on a distinguished road
boatmoter's Avatar
1993 SL2
if the battery light is on it most likely is not charging or the drive belt is off or slipping on the Alternator pulley, I would check the belt to make sure the tension is good and the tensioner has a strong pull on the belt, if thats ok,I would remove the alternator and have it tested.. never rule out a part jus because it's new in todays world of sub-quality parts.. even parts from the dealer
Add to boatmoter's Reputation
Rate the quality of this post and help boatmoter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
boatmoter is offline   Reply With Quote
Old 01-18-2015, 08:16 PM   #8
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
Replaced with what? If it was the $100 "remanufactured" special, it was probably lipstick on a pig.
All you need to do is to put voltmeter on the battery terminals while running. Is it too hard to do?
Add to jacek_p's Reputation
Flashing battery light not fixed by new battery. enviroko General Saturn Discussion 5 12-17-2015 01:05 PM
Troubleshooting intermittent airbag light bennett9000 S-Series Tech 7 01-12-2014 06:37 PM
'96 SW2 Service Wrench Light troubleshooting -Questions! BAD LS1 S-Series Tech 8 01-09-2013 07:49 PM
new battery, new alternator...still have battery icon light??? alarmer L-Series Tech 2 06-07-2009 01:14 PM
1995 SC2 Battery light on, battery OK Abe95SC2 S-Series Tech 4 09-24-2003 02:52 PM
