Old 10-18-2020, 09:04 PM   #21
TomM96
Default Re: Defelector spring
I've been using some select hardware store springs which affixed with wires, or attached to a bar on the far side. (?)
This is not precision grade; deflectors help airflow at low speed.
Old 10-23-2020, 08:36 PM   #22
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
I called around, and found a dealer who had three on hand and sold them to me for $25 CDN. Now I just need to find a fourth one somewhere...
Goggles Pisano is offline   Reply With Quote
Old 10-23-2020, 11:16 PM   #23
SRGW
SRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to allSRGW is a name known to all
1997 SL1
Post Re: Defelector spring
Member Mattwithcats was nice enough to send me 1 which was all I needed. Thank You again Matt.
1995 SL1 236,300 2005>2018
1997 SL1 85,100 2014>????
CHECK YOUR OIL!!
SRGW is online now   Reply With Quote
Old 10-24-2020, 02:01 AM   #24
mattwithcats
mattwithcats is a jewel in the roughmattwithcats is a jewel in the roughmattwithcats is a jewel in the rough
Check that package carefully, I put three springs in there...
NGK BKR6E-11 spark plugs
Old 10-24-2020, 09:48 AM   #25
SRGW
1997 SL1
Just rechecked package yes there are 3 springs.
Thank You again!!
Steve
CHECK YOUR OIL!!
Old 10-30-2020, 08:28 PM   #26
Goggles Pisano
1999 SL1
Funny story: I finally acquired four springs and I was finally ready to attach my air dam with springs again rather than with bolts. I was taking apart my struts and springs anyways, so I figured it would be a great time to do this. Having watched the Richpin video, I was all set.
The car was up on jackstands, the tires were off and I was ready to pull out those pushpin fasteners when I noticed something was amiss...
MY AIRDAM WAS MISSING.
Umm... oops?
I suspect that on my drive to Sat Catharines, I bottomed out a few times on the QEW and that may have forcibly separated the air dam from the under tray.
Needless to say, that particular project is now on hold.
Old 10-31-2020, 11:52 AM   #27
TomM96
About 8 years ago we had small snowstorm with some accumulation before commute to work.
When i pulled into parking lot, someone pointed out that something seemed to be dragging below my car (a spring let loose on one side of the dam).
That same day, another guy who drove a 'Neon', reported that his air dam
had also been lost.
Old 10-31-2020, 05:11 PM   #28
454cid
Umm... oops?
If it's any consolation, I didn't even know I was supposed to have an air-damn until this thread
2000 SL2 Automatic (back on the road) 19X,XXX miles.
1999 Chevy K3500
03 vue spring marmitage Vue Tech 1 02-26-2016 01:56 PM
Need help for my 96 SL2 this spring NotoriousJOE876 S-Series Mods 4 02-10-2010 06:37 PM
spring ? ion skater6912 Ion Tech 1 02-06-2006 08:31 PM
spring ?? jerm1 Ion General 2 11-24-2004 03:11 PM
Well, it's spring somewhere... daver General Saturn Discussion 20 03-01-2004 09:16 AM
