Old 10-03-2018, 01:50 PM   #21
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
2008 AURA XE
Default Re: 2007 Aura XR won't start (sporadic problem, not a dead battery))
A failing starter may crank intermittently it will not cause the tach to be inoperable.
Add to imaddicted2u's Reputation
Rate the quality of this post and help imaddicted2u reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-03-2018, 02:29 PM   #22
Originally Posted by floridasl22002 View Post
...... A clued up mechanic determined that the starter motor had developed 'flat spots'. When the thing stopped on the flat spots, there would be no contact to spin the starter. I guess minute movement then nudged it off the flat spot and it would start normally. Swapped out the Starter Motor and no more issues.
It's more likely for starter motor brushes to wear down causing 'flat spot' syndrome. Whether two or four brushes, they wear down. Spring pressure maintains electrical contact at all times until brushes wear down then less contact pressure results in a flat spot syndrome. Well worn brushes simply won't make good electrical contact against the commutator, the rotor with segmented copper contacts connected to windings around the rotor. Old school mechanics and some new school ones inheriting troubleshooting tips usually try banging the starter body with a rubber mallet - this can help worn brushes make contact for at least one more starter run. This presumes all other troubleshooting was completed to point to a worn out starter. It's rare for anyone disassembling starters to learn how they work and what causes them to fail. At one time or another, I disassembled and rebuilt one starter and alternator. The rubber mallet trick didn't work on one starter but it was replaced as the answer.
98 SW2 having sporadic starting problem, will not turn over, wait 30, starts right up nps-98SW2 S-Series Tech 35 03-21-2012 07:35 PM
2007 Aura XE brake light problem 2Lime4U Aura General 18 12-17-2011 08:27 PM
AM Radio Problem AURA 2007 XE donaldwebster Aura General 2 03-13-2008 09:20 AM
95 SL2 no start when hot (dead battery symptoms) skijay S-Series Tech 9 10-20-2005 07:43 PM
Vehicle wont start... Is battery dead? marmaduke L-Series General 4 10-17-2005 09:26 PM
