Old 08-10-2018, 08:07 PM   #1
odiaz1831
odiaz1831 is on a distinguished road
2003 ION-3 Sedan
Default Wheel Wells for 2001 SC2?
Hey guys, my two front wheel wells have ripped through a few of the clip holes. It makes my wheel well rub as I reverse or make an sharp turns. Which cars should I go scavenging from a junkyard that would fit the 2001 sc2? Or is there a way to fix it? The plastic just tore by the hole for the plastic clips.
Add to odiaz1831's Reputation
Rate the quality of this post and help odiaz1831 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
odiaz1831 is offline   Reply With Quote
Old 08-10-2018, 08:53 PM   #2
Zeebins
Zeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to allZeebins is a name known to all
Zeebins's Avatar
Default Re: Wheel Wells for 2001 SC2?
According to the part number, (21111964 and 21111965) only 2001 and 2002 are compatible. You could probably just hold it up with some duct tape for now though if it's becoming a problem.
"Tupperware on wheels"
1997 SL2, 110K miles
Add to Zeebins's Reputation
Old 08-10-2018, 09:05 PM   #3
I have fixed a lot of Saturn and Mazda plastic with fiberglass.
Add to Waiex191's Reputation
Old 08-10-2018, 09:26 PM   #4
Clean, scuff up good with sandpaper, and put a few layers on the front side. At least one on the back. Redrill the hole after it has cured.
Old 08-10-2018, 11:26 PM   #5
odiaz1831
2003 ION-3 Sedan
Awesome. This is exactly what I was looking for. I was thinking of using bondo, but just knew there was a better choice for the job. Thanks!
Old 08-10-2018, 11:28 PM   #6
odiaz1831
2003 ION-3 Sedan
Dang I'm probably going to have trouble finding it at a salvage yard. Thanks for the part numbers I'll see what the internet finds for me.
Old 08-10-2018, 11:35 PM   #7
odiaz1831
2003 ION-3 Sedan
Never really used fiber glass. By the looks of your pictures I nee fiber glass tape, and then I layer the fiber glass bondo resin on top of the tape?
Old 08-11-2018, 12:04 AM   #8
You need resin:
https://m.lowes.com/pd/Bondo-32-fl-o...Repair/3371926
And you need cloth:
https://m.lowes.com/pd/3M-White-Fibe...-Cloth/3228210
Get the cloth that looks like weaved fabric and not the mat that looks like a bunch of fibers jammed together. It is not tape. You cut out the shape you need.
My links were from Lowes but any hardware, auto, or Walmart type store should have it.
I use disposable chip brushes, 1" is good. Paint resin on the area, stick the cloth on, then use the brush to saturate the cloth by stippling with the brush. That means to jab into the cloth like you are stabbing it with the bristles.
If you Google the YouTube it should have a video. Easy stuff.
Old 08-11-2018, 07:32 AM   #9
Stephanie on YouTube did the perfect video for you:
https://youtu.be/4leRPhXT3ug
Old 08-14-2018, 05:00 PM   #10
TomM96
I KNOW Dorman sold some Saturn wheel liners (maybe not that year+model).
I would check:
RockAuto
PartsGeek
maybe CarID
Add to TomM96's Reputation
oil in wheel wells Ol'Saturn Vue Tech 34 04-06-2016 06:55 PM
Front wheel wells cam Ion Tech 7 06-30-2011 11:06 PM
ION 3 front wheel wells cam Ion General 3 06-08-2011 11:07 PM
Ice / Mud build up in rear wheel wells. 02VUE93SL Vue General 10 02-13-2003 09:16 PM
Keeping snow and slush out of the wheel wells David 93 SL2m Miscellaneous Tech 0 01-04-2001 09:47 AM
