Old 05-01-2018, 10:42 PM   #61
Waiex191
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Waiex191's Avatar
Default Re: 98 SC2 project. Drive for now, maybe rebuild later.
The window tint remover did not work at all. I also tried naptha, acetone, and brake fluid. No joy. I am going to get a good scraper and go to town. I'll lose the window heat but at least I'll be able to see most of the time. Thanks for the YouTube link Mark, I'll check it out.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 05-01-2018, 10:59 PM   #62
Windex will work if you are patient.
Old 05-01-2018, 11:38 PM   #63
Mark_b
Mark_b is a jewel in the roughMark_b is a jewel in the roughMark_b is a jewel in the rough
Ok one more link if you have to recharge your AC system.
https://www.youtube.com/watch?annota...&v=Pdq8JAlct6s
There are many more but this one is pretty straight forward.
Mark_b is offline   Reply With Quote
Old 05-02-2018, 09:30 AM   #64
Waiex191
Waiex191's Avatar
It almost seems like spray on tint, or it is the adhesive from the film we pulled off.
Bryan Cotton
Old 05-02-2018, 09:35 AM   #65
edit: just saw your post - you already pulled the tint off and are dealing with residual glue?
+1, this is from someone who retired from the window business, from another forum.
Solar films are polyesters and water soluble so over time the ammonia water mix soaks through the film and loosens the adhesive. The longer the film was on the longer the removal time as the adhesive loses elastomers and hardens.
He recommended 20% ammonia, 80% water.
Windex is 5~10% ammonia. Probably safer at this concentration since you want to protect the heating elements. You'll want to lay down a plastic bag or towels to catch any overspray, as ammonia can bleach spots if there is enough, left on long enough.
use a micro-fiber towel, dampened in water or water/white vinegar mix, to clean tinted windows
I plan on pulling the PO's dark tint off my SC2 eventually. Looks purple from the inside and can be hard to see out of at night
Old 05-02-2018, 06:50 PM   #66
Waiex191
Waiex191's Avatar
This is what I've got.
Bryan Cotton
Old 05-02-2018, 07:39 PM   #67
That is going to take time.
Old 05-03-2018, 11:02 AM   #68
^ ^ ^ yeah, that looks like leftover adhesive from the tint. It separated from the film and stuck to the window. Nasty stuff.
I would use (in a well ventilated area) a cotton ball with Goof Off mostly squeezed out (to avoid any drips) but only in the spaces between the grid lines, staying away from the lines to get the bulk of it off.
But wait a bit for comments before trying this - in case someone has had Goof Off destroy their grid lines (you can kind of shape the cotton balls into narrow shapes).
Not sure what I would do with the gridlines themselves, though. Maybe the Windex on cotton balls, going slow and light along the lines. Or a 5% ammonia mix, not on the glass itself, but sprayed on a paper towel, placed on a large garbage bag, taped underneath the window and placed in the sun for maybe 15~30 minutes so that the evaporating solution softens up the adhesive (cribbed from one of OldNuc's suggestions in another tint thread )
Not sure what a steamer (if available) would do to the gridlines.
Old 05-03-2018, 11:57 AM   #69
Heat applied to local areas can damage the glass due to local stresses.
Goof Off is some mix of hydrocarbons and may not accomplish anything. It is not my favorite cleaner.
Orange oil, this stuff tends to cut through many odd goos. Dilute with distilled water. You should be able to find smaller quantities to give it a try locally. https://www.amazon.com/D-Limonene-Ex...70_&dpSrc=srch Straight Purple Power is also a high Ph product that might cut into the well oxidized adhesive.
Old 05-05-2018, 08:04 PM   #70
Waiex191
Waiex191's Avatar
We put in the new hydraulics. They seem about the same as the ones I took out. I am wondering if the fingers on the clutch spring​ or the throwout bearing is worn. I can now sometimes get it into third.
I greased the clutch pivots​. It is hard to reach to replace the clip. I stuck wood underneath to help get it on.
We took the shift tower off. Easy to shift into reverse here.
This dust cap pulls off, then an E clip is removed.
Here is the flattened pin OldNuc mentioned.
Here it is vise gripped to twist 90 degrees.
There is lost motion still. I don't think​ it is in the shift tower. Maybe the worn shifter? Maybe bad cables? If I push in on the shift tower to help the cables, it goes into reverse like butter.
I think I know why the air does not work.
Condenser looks pretty bent!
Bryan Cotton
Old 05-05-2018, 09:43 PM   #71
Either cut the rivets so you can disassemble the inside shift tower and get the slop out of the shifter or go to JY and pluck one out of an 02 Saturn as they are all identical. Get the cables along with the inside tower. Sounds like yours has expired.
Old 05-06-2018, 05:34 PM   #72
Waiex191
Waiex191's Avatar
Is it possible my worn shifter is causing the third gear grind? Maybe it is not lined up in the center. Third gear is slightly better since we turned that pin. I am definitely going to get a shifter from the junkyard.
Today I finished scraping the window. This was partway there. It is nice to be able to back up safely again.
We popped out the passenger seat. The right front bolt was a mess. Ended up wetting down the carpet and grinding it off. The lock on the left side of the picture is not seating well. This was also preventing the other side from seating. The seat kept sliding fore and aft. We have not figured out what is wrong yet.
Bryan Cotton
Old 05-06-2018, 07:12 PM   #73
The wire connecting the latches does not look OEM and might be a bit short. Disconnect and see if the latch locks in properly.
Window is starting to clean up.
The gear problem is in the cables, inside selector tower, and outside tower. You probably fixed the outside tower but the cable end bushing outside also wears out, it is the cable that connects to the arm with the pin.
Old 05-06-2018, 08:19 PM   #74
Waiex191
Waiex191's Avatar
The cable looks stock to me. I took it off. The one on the right of the picture latches well, on the left of the picture (with the torque rod) it does not.
Bryan Cotton
Old 05-06-2018, 09:25 PM   #75
Check the latch cam, part of the release lever, is not full of goo. That will hang up the latch pawl.
Old 05-07-2018, 08:08 PM   #76
Waiex191
Waiex191's Avatar
We took out the passenger seat. I have a hole to drill and tap. Here is a fun max legroom picture on the way to scouts yesterday.
I unbolted the non-locking track. Popped off the e clip that held the cable.
So, this pawl is keeping the seat from locking.
If I rotate the pawl out of the way, this side latches nicely.
It looks like when you slide the seat backwards and put the seatback up, this tab should hit a tab that releases the pawl. I see lots of worn metal. Anybody have a picture of a good one?
In other news, I had to bump start it twice today. The volts measured 14.2 while running, and 13.9 after sitting. We noticed a few things:
1) ground wire looks bad at the block.
2) starts have seemed weak lately
3) the starter will never rust. Plus it is a Saturn, all starters are bad.
Also yesterday I verified the reverse switch is bad.
Bryan Cotton
Old 05-07-2018, 08:37 PM   #77
The starter is full of oil and shot. If you take it apart you will find the insides are oil soaked and the commutator is likely completely black. DBElectric sells the replacement. I have a set of gen-2 98 seats so I can get the pix you need tomorrow.
What is supposed to happen with that seat is with the seat pushed back aways and then you want access to the rear seat you lift up on the back release lever and the back springs forward and the seat unlatches on both sides and runs all the way to the forward stop. When you wish to restore normalcy after loading the people or dogs in the rear you lift up on the seat adjuster lever and push it all back by pushing on the back rest. Verify it is not functioning as the other car does.
Old 05-08-2018, 01:38 PM   #78
On the passenger side ther is a cable that runs from the right hand side seatback release mechanism that pulls that latch when the back is in the full forward position. This also releases the left side and right side bottom track latches so the seat runs forward with the back folded to the max folded to the front position. Then the cable is present it goes slack when the back is latched into the first upright position. The cable is shown in your first picture and it is this cable that pulls the latch when the seat back is latched into its first upright notch. The seat back is spring loaded to swing forward when the lever is lifted and this also conveniently unlatches both main latches to allow the seat to run full forward by just releasing the back. Operating this when everything is not bolted down is less than simple.
Old 05-08-2018, 01:55 PM   #79
Mark_b
Richpin seat repair
https://www.youtube.com/watch?v=v2k8qPoB8cI
Maybe this will help.
Old 05-08-2018, 02:06 PM   #80
Waiex191
Waiex191's Avatar
Thanks both of you for the info and links on the seat.
I have a DAB electric starter on the way, and a new ground cable. The car starts when cold. It seems 90 minutes of cool down is enough. Overnight is no problem, but the start is still a little weak. I am parking strategically. Long live the manual transmission!
Bryan Cotton
Summer Project:1.9 Engine Rebuild 1bignordic S-Series General 5 03-17-2014 02:29 PM
Rebuild VS Drive it as is VS sell it off OldSkewlSW1 S-Series General 11 03-09-2009 05:27 PM
Updated rebuild project hAnNibAl_H S-Series Mods 8 06-18-2007 12:17 AM
Current Project Towing New Project popp Vue Red Line 6 04-11-2006 12:55 AM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
