Old 05-07-2014, 08:57 PM   #1
WVUDave
WVUDave is on a distinguished road
2002 SL1
Default Poor Gas Mileage/Running Rich?
I do almost exclusively city driving, and I'm only getting about 225 miles before the low fuel light turns on. I'm not certain, but I do believe I used to do much better. I also have a fuel gauge that doesn't always work. In addition, service engine soon light is on for code P0137. Should I be concerned?
No exhaust leak as far as I can tell.
Engine also intermittently stutters (like a hiccup) when idling, except when I have the air conditioning on. The hiccup feels similar to when an engine stalls, but is only for a second and resumes to normal.
Could it be the carburetor?
I am open to any ideas and suggestions. Thank you kindly.
WVUDave is offline   Reply With Quote
Old 05-07-2014, 09:11 PM   #2
SaturnAndBeyond
SaturnAndBeyond is on a distinguished road
SaturnAndBeyond's Avatar
1992 SL2
Default Re: Poor Gas Mileage/Running Rich?
There's not really a "Carb," per se: All air/fuel ratios are controlled by the computer. If you think the engine might be running rich, I'd suggest replacing the O2 sensor. I'm not sure where that might be on your particular car, but there are probably a few people on here who know.
1992 Saturn SL1 "Sally"(Scrapped, 10Jul16)
1992 Saturn SL2 "Baby Blue"
2000 Subaru Forester S "Eileen"
2010 Subaru Impreza WRX "Sophie"
2014 Suzuki Boulevard M50 "Suzie"
SaturnAndBeyond is offline   Reply With Quote
Old 05-08-2014, 01:50 PM   #3
WVUDave
2002 SL1
Any other suggestions besides o2 sensor?
Old 05-08-2014, 02:03 PM   #4
Clean the PCM and sensor grounds on the left rear corner of the block just under the #4 intake runner. They are 4 wires bolted to the block, don't drop the bolt.
Check the exhaust for any leaks between the head and CAT inlet.
Exhaust leak check.
--Locate a low pressure high volume air source, reversible vacuum cleaner, large fan, leaf blower or what ever you can find.
--Loosely couple to cold exhaust at the tail pipe, or direct fan at tail pipe.
--Spray every inch of the exhaust between the head and CAT inlet with a mixture of 2 or 3 drops of dish soap and water in a spray bottle.
--Pay close attention to the lower flange, lower support clamp, and flex connector.
--The flex connector is under the protective braid so it requires quite a bit of solution to show any leaks.
Old 05-08-2014, 02:06 PM   #5
GeekOnTheHill
GeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the roughGeekOnTheHill is a jewel in the rough
GeekOnTheHill's Avatar
Well, P0137 does in fact relate to the O2 sensor, so that's the logical place to start.
In addition, I'd start looking at simple possibilities like:
Dirty air filter
Worn or fouled spark Plugs
Old spark Plug Wires
Dirty throttle Body
You know. Those sorts of things. Also, obtaining an actual MPG reading wouldn't be a bad starting point.
-Richard
GeekOnTheHill is offline   Reply With Quote
Old 05-08-2014, 03:12 PM   #6
It is the rear sensor though so I does nothing to mixture. Low voltage is usually dirty grounds.
Old 05-08-2014, 04:48 PM   #7
Mileage, maintenance done, parts replaced? Worn, damaged catalytic converter ever considered? While there are as many suggestions as members, troubleshooting some problems requires some careful steps to narrow a mystery problem, starting with simple wiring checks for looseness, corrosion, abrasion (chafing) on long wire lengths not tied out of the way, etc.. Since this error code is for the rear O2 sensor, this can mean either the sensor or the catcon. At worst, a problem further up or downstream is causing the error code - tied to poor fuel economy.
Old 05-08-2014, 10:55 PM   #8
WVUDave
2002 SL1
I'm getting 25 MPG.
New wires, plugs, cleaned throttle body.
Old 05-08-2014, 10:58 PM   #9
WVUDave
2002 SL1
Haven't found leaks.
Thinking my converter may be clogged/bad.
Old 05-08-2014, 11:01 PM   #10
Clean the sensor grounds.
Old 05-09-2014, 07:12 AM   #11
Originally Posted by WVUDave View Post
I'm getting 25 MPG.
Sorry, I meant odometer mileage as catcon wear and tear may be a consideration with high mileage cars.
Old 05-09-2014, 08:59 AM   #12
WVUDave
2002 SL1
Just under 110,000 miles.
I'll try cleaning the ground sensors.
Running very rich. Black Bear S-Series General 12 01-24-2013 10:35 AM
Running rich sunnfish S-Series Tech 1 02-26-2011 03:39 PM
SL2 gas mileage (RICH EXHAUST MAKES ME POOR) rudedog23 S-Series General 13 12-10-2007 04:56 PM
Running pig rich! Steedo S-Series Tech 6 11-16-2005 10:56 AM
Poor MPG, Running rich w/ Rotten Egg Smell Visseroth S-Series General 34 10-22-2005 01:46 PM
