Old 03-20-2013, 05:49 PM   #1
aa4lr
aa4lr has a spectacular aura aboutaa4lr has a spectacular aura about
Question Coolant Leak on Passenger Side - Water Pump?
I have a 1995 SC1 with over 180,000 miles on it. The engine has about 60,000 miles less (it was replaced before I bought it).
Recently, I had a low coolant light come on after driving 85+ miles home. Took more than a quart of coolant, and I had topped it up just a week before.
Parked it on the car port, and just a few minutes of idling will show a leak on the passenger side -- it drips off the front and back of the sub-frame below the engine. It looks like some is spraying off the serpentine belt.
Doesn't appear to be anything coming from either end of the radiator, or the hoses or thermostat housing.
I'm thinking the water pump may have given way, but it is hard to tell -- difficult to see that side of the engine.
Thoughts?
Bill Coleman
2001 Saturn SC2 Auto (3/13-...) "Yellow"
1999 Saturn SL2 Auto (11/09-...) "White"
1995 Saturn SC1 Manual (9/08-...) "Gold"
1994 Saturn SL1 Auto (7/94-1/04) 144,000 miles "Green"
Add to aa4lr's Reputation
Rate the quality of this post and help aa4lr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
aa4lr is offline   Reply With Quote
Old 03-20-2013, 06:40 PM   #2
colonelhogan44
colonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of lightcolonelhogan44 is a glorious beacon of light
colonelhogan44's Avatar
Default Re: Coolant Leak on Passenger Side - Water Pump?
Water thrown by serpentine belt = water pump leak. Replace that sucker.
Take the PS wheel off, remove the two lower splash shields to gain easy access to the pump. Make sure to get the mating surface very clean (I use a razor blade).
If the belt is old, replace that while you're down there, since it's much easier with the splash shields removed.
Cheers
MechE - I make things!
EGR ADAPTERS AVAILABLE! $30 "reverse" $40 standard
1998 SL2 (gone, never forgotten)
2005 Volvo S40 T5 AWD
1987 Mercedes 300D
1993 Tracker 4x4
1996 Tracker 4x4
Add to colonelhogan44's Reputation
Rate the quality of this post and help colonelhogan44 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
colonelhogan44 is offline   Reply With Quote
Old 03-20-2013, 08:18 PM   #3
aa4lr
Wrench Re: Coolant Leak on Passenger Side - Water Pump?
Cheers
Got it up on jacks and took the wheel and splash guards off. Got the pulley off the water pump and it was pretty obvious -- even not running, coolant is dripping out of the shaft.
I'll grab one tomorrow from the parts place.
Bill Coleman
Old 03-21-2013, 12:59 PM   #4
el diablo viejo
el diablo viejo's Avatar
1994 SW1
Don't use a razor blade or any metal scraper as you may accidentally nick the aluminum mating surface. Use a plastic scraper for the heavy stuff and then a green scuff pad for the rest of the residue. Much more of a pain but much safer outcome. Get it all nice and shiny before reassembly. Do not overtorque the bolts. Not a bad idea to use all new universal antifreeze when you refill the system. Good luck
97 sl2 a/t 104 K
Add to el diablo viejo's Reputation
Rate the quality of this post and help el diablo viejo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 03-21-2013, 01:31 PM   #5
proveniebam
proveniebam is a jewel in the roughproveniebam is a jewel in the roughproveniebam is a jewel in the rough
"Spray off the serpentine belt." Was down a cup after every 50 miles.
I had that but it was the coolant bottle itself leaking. Replaced with a good JY and problem disappeared.
If getting an used coolant bottle make sure when you shake to see if it rattles. If it don't it's no good.
Add to proveniebam's Reputation
Rate the quality of this post and help proveniebam reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
proveniebam is offline   Reply With Quote
Old 03-25-2013, 10:57 PM   #6
kdrake78
kdrake78 is on a distinguished road
I am a SUPER NOOB. I just bought a 98 S-series Wagon today and got it home and noticed the same thing, coolant leaking on the passenger side... I looked under the hood and didnt notice any leaks out of the hoses or any notice of leaks or spray...
Any thoughts? Thanks!! Kurtis
Add to kdrake78's Reputation
Rate the quality of this post and help kdrake78 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kdrake78 is offline   Reply With Quote
Old 03-26-2013, 12:41 PM   #7
el diablo viejo
1994 SW1
You need to check the water pump behind the pulley. Either from underneath or take off passenger side front wheel and then the plastic panels.
97 sl2 a/t 104 K
Coolant leak at water pump Tercero S-Series Tech 8 08-31-2012 09:13 PM
2.2L I4 Coolant Leak - Water Pump? 16Victor Vue Tech 5 06-12-2011 11:03 AM
Coolant leak from water pump jonnycube S-Series General 36 08-17-2009 07:37 PM
SL1 FAST water leak - passenger side shibbard1675 S-Series Tech 3 07-31-2008 09:52 AM
Water Leak-Front Passenger Side 02 SC2 pghsatrngrl S-Series Tech 1 05-14-2008 09:20 PM
