Old 08-21-2019, 08:47 PM   #1
TwoFistedJustic
TwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the roughTwoFistedJustic is a jewel in the rough
Default What parts to replace during engine rebuild?
2002 SC2, Manual
I'm preparing to have my engine rebuilt through a local shop.
The owner said that they can swap out any parts that they have to pull off anyway ( that aren't normally part of a rebuild) for no additional charge if I provide the parts. In this case a rebuild is bearings, pistons, rings and such. I'll get a complete list of parts when I get the formal estimate.
They'll be using Silvo-lite pistons.
The parts I already have for them to replace:
new Denso radiator
new clutch plate, flywheel, throwout bearing
What else should I have replaced since the engine is going to be out and apart anyway?
TwoFistedJustic is offline   Reply With Quote
Old 08-21-2019, 10:45 PM   #2
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Default Re: What parts to replace during engine rebuild?
My thread is here:
http://www.saturnfans.com/forums/sho...d.php?t=230898
I have new pistons, bearings, water pump, alternator, oil pump, timing chain, engine mounts, injector o-rings, IAC valve, TPS, rod bolts, and of course seals/gaskets/head bolts.
Old 08-22-2019, 01:39 AM   #3
KevzSL2
KevzSL2 is on a distinguished road
What intake manifold are you going to use?
An original 17yr old plastic intake is NOT the ticket...
KevzSL2 is offline   Reply With Quote
Old 08-22-2019, 06:47 PM   #4
TwoFistedJustic
I assume you are referring to the problem where the coolant pipe breaks? Already happened. I replaced it with the steel part from carsaturn.com
Or were you referring to some other problem that I have failed to already have happen to me?
Old 08-23-2019, 11:59 PM   #5
KevzSL2
You got it already! (Yes, I was referring to that darn plastic pipe). Glad you got that fixed.
Engine Rebuild Parts Brand Sujestions Saturninin S-Series General 10 09-17-2015 11:11 PM
Is it better to Rebuild or Replace the Engine for a 1993 SC2 Saturn? 93sc2saturn S-Series General 10 04-09-2013 03:35 AM
Full 2000 (Motor) DOHC Rebuild - Parts to replace / or just buy rebuilt? Aysle S-Series Tech 6 01-18-2011 05:57 PM
'95 SL2 for parts or engine rebuild karty72 Classifieds 20 06-07-2005 01:07 PM
Best place to buy parts for engine rebuild? Matt SL2 L-Series General 1 05-30-2005 05:16 PM
