Old 08-12-2019, 08:52 PM   #41
Default Re: A/C Schrader valve leak
Originally Posted by Waiex191 View Post
I charged the system 70 hours ago, and still have 43F air coming out.
HillBilly fix is working
Old 08-12-2019, 11:01 PM   #42
Waiex191
Waiex191's Avatar
Yep, long live the hillbilly fix. fdryer, I am sure it won't last forever, but I'd be happy with a couple of months! I really want to fly the airplane this year.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 08-12-2019, 11:12 PM   #43
The way these things work out is like this: if it lasts for 24 hours then it may be considered a permanent fix.
Old 08-13-2019, 09:19 AM   #44
Silverblu02SL2
Exactly, I have little to lose ($15 worth of Walmart R134a) and much to gain. Whether I cut and flare or replace, there is a lot of work to get the tube out.
How about a split short length of hose with a hose clamp over it to seal the chafe?
Add to Silverblu02SL2's Reputation
Rate the quality of this post and help Silverblu02SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 08-13-2019, 10:39 AM   #45
Most hose is R-134a permeable, that would be a slow leak.
Old 08-13-2019, 10:45 AM   #46
Waiex191
Waiex191's Avatar
The patch is steel. Its rate of chafing is slow. Mainly I used the patch to give more surface area to the bond. As the low side pressure tries to push up through the leak, it would have to move the patch which has generous surface area.
Bryan Cotton
Old 08-13-2019, 11:03 AM   #47
As long as the epoxy holds it is permanent fix.
Old 08-13-2019, 11:36 AM   #48
Yep...... hillbilly fix. ...... I'd be happy with a couple of months! I really want to fly the airplane this year.
Some of us go to great lengths to have air conditioning. When your silver bullet with wings leaps into the air, post a few snapshots.
Old 08-13-2019, 01:44 PM   #49
Waiex191
Waiex191's Avatar
Will do! In the meantime this is a recent picture.
Bryan Cotton
Old 08-14-2019, 11:44 PM   #50
Waiex191
Waiex191's Avatar
Deleted post. mifertos is a spammer.
Bryan Cotton
Old 08-15-2019, 01:16 PM   #51
Yes, most likely due to this post, http://www.saturnfans.com/forums/sho...03#post2304803, revealing his/her true motives. Charlie was informed.
Old 08-22-2019, 03:59 PM   #52
S-forever
S-forever is on a distinguished road
1991 SL2
Originally Posted by solidhadriel View Post
I bought the tool of amazon to replace my high pressure valve stem. It was about $40-$50 and made the job super quick and simple.
Unfortunately, my AC does not blow cold even with a proper charge. So I have to look at replacing my AC condensor...
Not blowing cold can be other things besides the condenser. If the system was opened and wasn't drawn to a proper vacuum for long enough, or the expansion valve is stuck, the system won't work even with a proper charge and good compressor.
Add to S-forever's Reputation
Rate the quality of this post and help S-forever reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
S-forever is offline   Reply With Quote
Old 08-22-2019, 06:30 PM   #53
Waiex191
Waiex191's Avatar
solidhadriel hasn't been on here in about 3.5 years. My air is still good! I'm claiming victory.
Bryan Cotton
a/c schrader value leak gmcelroy S-Series Tech 14 06-21-2011 08:09 AM
schrader valve? bboy29 S-Series General 6 12-16-2009 11:15 PM
A/C replace schrader valve on high side RobertGary1 S-Series Tech 5 10-03-2009 11:05 AM
ac schrader valve (hi and low) STLWACO S-Series Tech 14 11-28-2006 12:36 PM
Schrader valve Bigbadbert Miscellaneous Tech 11 06-16-2004 04:01 PM
