Old 07-30-2010, 02:43 PM   #1
sprinj76
sprinj76 is on a distinguished road
sprinj76's Avatar
1997 SC2
2006 ION Red Line
Default Oil Pressure Gauge Solution
http://www.glowshiftdirect.com/Oil-F...-Adapters.aspx
Anyone tried something like this? There was talk of it on BITOG forums and it seems like a neat solution, and reasonably priced. This way you would not need to remove a plug from the block, or add an adapter to the idiot light location.
Anyone know the stock threads on the oil filter?
My only concern would be any flow restriction from adding something like to the oil filter.
Every couple weeks or so someone brings up how to install an oil pressure gauge, and most are scared away due to the procedure of installing one. This might help, a lot.
Thoughts? Comments?
Black Onyx '06 Ion Redline w/ comp package
Red '97 SC2 5-speed --sold
sprinj76 is offline   Reply With Quote
Old 07-30-2010, 02:56 PM   #2
sprinj76
sprinj76's Avatar
1997 SC2
2006 ION Red Line
Default Re: Oil Pressure Gauge Solution
Threads: 3/4 - 16
Old 07-30-2010, 03:30 PM   #3
1996SL11.9L
1996SL11.9L has a spectacular aura about1996SL11.9L has a spectacular aura about
1996SL11.9L's Avatar
2002 SL1
looks good, and to add to it with the filter base spaced off the block a larger oilfilter like a PH8A (mopar, small block ford) style filter should fit and not hit the belt guard do to its larger Diameter.
Only clearence that becomes questionable is how close does the larger filter get to the half shaft.
1996SL11.9L is offline   Reply With Quote
Old 08-22-2019, 02:52 PM   #4
S-forever
S-forever is on a distinguished road
1991 SL2
For seven dollars more, you can buy an oil cooler adapter with two ports for oil temp/pressure senders. Just look on the glowshiftdirect site for "/oil-cooler-sandwich-adapter-3-4-unf-16-thread".
I'm seriously thinking of ordering this even if I loop/bypass the oil cooler holes for now. I doubt it's set up to work if they're just plugged. My daily driver is getting older(340K miles on original '97 SL2) and I want to monitor the oil pressure. Any thoughts on this? Obviously, the regular sandwich adapter is a quicker install. Reaching the oil filter area is quick and easy through the right wheel well, and you don't even need to get under the car.
S-forever is offline   Reply With Quote
Old 08-22-2019, 06:26 PM   #5
SC2Sick
1997 SC2
1995 SW2
You're 9 ( NINE ) years late to the party
sixthsphere.com owner
2002 Saturn SC2 - RHD
SC2Sick is offline   Reply With Quote
oil pressure gauge MikeNW S-Series Tech 3 03-22-2010 05:09 PM
Where to get an oil pressure gauge Blammer S-Series Tech 9 11-29-2007 12:06 PM
Oil Pressure Gauge djb383 Vue Tech 0 08-23-2006 10:46 PM
oil pressure gauge koolkash_45 S-Series General 3 10-08-2005 11:45 AM
removed odometer from gauge cluster, now gas gauge & oil pressure gauge don't work DJboozeAlot S-Series Tech 18 04-06-2005 03:59 AM
