Old 04-14-2019, 07:06 AM   #201
Waiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really niceWaiex191 is just really nice
Default Re: 98 SC2 project. Drive for now, maybe rebuild later.
I bought this car one year ago today. Overall it has been good minus the adventure of changing the fuel filter and the collateral projects that caused. I have put about 8000 miles on it.
Old 07-08-2019, 10:51 PM   #202
I think I've inadvertently started polluting the "what did you do to your Saturn today" thread so I'm moving back here. Brief synopsis: car was stumbling, and I undid the IAT mod. Still stumbles, and bogs at WOT through a wide RPM range. Newish plugs, wires, Wix fuel filter, gets 30+ MPG consistently. Homework: pull the codes.
The car has a P0420, catalyst system efficiency below threshold. We have had this code since I bought it April 2018. The new code is P0303, cylinder 3 misfire.
I now have live data so can look at more stuff. I'll be driving the Saturn again as the air conditioner clutch in the $200 Buick is screeching
Old 07-08-2019, 11:05 PM   #203
Check the compression in #3 in comparison to#2 no need to do a full set. This could still be ignition or timing. I will have to dig into what all goes away when you get solid misfires, I don't think anything is dropped though.
If you can see the ignition timing see what it looks like.
That CAT is finished and may be broken up and blocking the exhaust. Can you make it go away?
Old 07-09-2019, 06:54 AM   #204
I'll have to see how hard it is to pull the cat. If I remove it will the ECU be unhappy?
Old 07-09-2019, 08:44 AM   #205
The 420 will be permanent unless you use an anti fouler on it. They are on eBay already drilled out. A 420 is only a light, no other action. Wagner makes a direct fit replacement cat and they are welded at the inlet end, clamps will not work.
Old 07-09-2019, 08:55 AM   #206
As to the 303 the first step is to find out if it is a burned valve or an ignition issue. From an ambient temperature start let the car sit and idle until it has reached normal operating temperature and the fan cycles once. Do not touch the gas through this. The question is this: is it running smoothly on all 4 cylinders through this evolution? If the answer is yes then the cause is likely ignition. The ICM is the only thing other than a plug and/or wire that can drop a single cylinder. That "wire" also might include a cracked coil tower.
Old 07-09-2019, 09:04 AM   #207
ErikTande
ErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the roughErikTande is a jewel in the rough
ErikTande's Avatar
the 303 is almost certainly bad or dirty coils, I've had that happen on a couple different Saturns.
http://www.youtube.com/velocitylabs
ErikTande is offline   Reply With Quote
Old 07-09-2019, 09:17 AM   #208
The DOHC is very good at burning #3. It happens real fast.
A coil failure usually impacts BOTH cylinders on that coil, there are exceptions.
Old 07-09-2019, 12:57 PM   #209
I'll do OldNuc's test when I get a chance. I am leaning towards coils as it comes and goes. On today's commute I didn't get any hesitation or bogging at all. I would think if I burned a valve, it would be burned.
Old 07-09-2019, 01:08 PM   #210
YES, if random then it is ignition. Keep in mind the ICM is the only component that will drop a single cylinder and they also generate random failures. If you have the coils already swap them both in and see what happens.
Old 07-09-2019, 01:46 PM   #211
focusofheart
Originally Posted by Waiex191 View Post
A few questions for the group:...
3) Has anybody removed window tint from the inside of the back window before or will that end in tears?...
I had my tint removed and they damaged the back window defroster so you might look at this youtube.
https://www.youtube.com/watch?v=xhBEEC5seEA
Saturn 1998 - SL2 automatic
Old 07-09-2019, 01:48 PM   #212
My rear defroster is toast, meaning it never gets toasty. I figured it was better to be able to see 95% of the time rather than worry about the 5% the heater was there for.
Old 07-14-2019, 12:26 PM   #213
Old coils.
Here are my new NGK coils. I cleaned up the ICM and the mounting pad on the gearbox.
It ran good on the short drive back home. This week I'll be driving the $200 Buick before I turn my kid loose in it. Plus it has AC.
Old 07-14-2019, 02:45 PM   #214
Those old coils are not passing the eyeball test so you probably found the problem.
Old 07-16-2019, 09:08 AM   #215
The Buick is still leaking from the high side schraeder valve. I've parked it in the hangar so it will be cool for tonight. The SC2 was awesome on my 14 mile commute. Hardly a definitive test but I am thinking I like the new coils.
Old 08-03-2019, 09:44 AM   #216
Not quite a year ago I recovered my passenger side visor. I glued the fabric on. Worked good until the heat of summer. Lately it has been springing back open. Here was the original post:
http://www.saturnfans.com/forums/sho...&postcount=135
I fired up the trusty Singer and sewed it together. Not super pretty but functional!
Coils are still good. Fuel economy seems very good based on how many miles I have at a quarter tank.
Old 08-22-2019, 04:02 PM   #217
d0ugparker
d0ugparker is a jewel in the roughd0ugparker is a jewel in the roughd0ugparker is a jewel in the rough
d0ugparker's Avatar
When I solder wires I like to bend one set back on itself, so the unsoldered wire supports the joint.
Smart; I'll use that.
Here is shrink tubing over the joints:
And a bigger piece of shrink tube over the whole thing.
I have to laugh when I think of how many times over the years I've
  1. soldered wires,
  2. THEN addressed the location of the shrink tubing.
Yeah... that.
IMO, this phenomenon needs its own catch phrase, like perhaps "Running before planning the race," or "Doing before thinking," or "Forgetting the bullet [point]," (like how everyone knows what a Catch-22 is) but I don't think it has one yet.
I kind of like the bullet one, humorously implying shoot me in the head for forgetting the darn thing in the first place!
"I went to slide the heat shrink over the solder joint, but I'd forgotten the bullet."
d0ugparker is offline   Reply With Quote
Old 08-22-2019, 06:23 PM   #218
Ready, fire, aim! is a good one. We've all done it!
Glad the post was helpful. The '98 is running great. I just pulled down 31.7 MPG without really trying.
Old 09-10-2019, 07:55 PM   #219
I bought this car about 17 months ago for $500. While driving home, I was accelerating WOT in third gear and 5000 RPM when I rolled my 10,000th mile. I've got about 172,600+ on it. I've been over 32 MPG the last few tanks. My SES light has been off a couple of days. Not sure if it was luck, the new coils, or the heated air intake sensor mod. I had been getting the old P0420. Overall I'm happy with my purchase.
Old 10-15-2019, 07:47 AM   #220
You may remember my heater mount from last year.
It earned me an award from alordofchaos.
One thing I didn't like about it was that it blocks the view out the back. Here is revision 2.
Summer Project:1.9 Engine Rebuild 1bignordic S-Series General 5 03-17-2014 02:29 PM
Rebuild VS Drive it as is VS sell it off OldSkewlSW1 S-Series General 11 03-09-2009 05:27 PM
Updated rebuild project hAnNibAl_H S-Series Mods 8 06-18-2007 12:17 AM
Current Project Towing New Project popp Vue Red Line 6 04-11-2006 12:55 AM
Seeking advice on engine rebuild (Subaru.. and rebuild done) Scyan Miscellaneous Tech 8 06-13-2003 09:38 AM
