Old 04-08-2018, 07:59 PM   #281
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default Re: 1996SL11.9L's 2002 SL1
Originally Posted by OldNuc View Post
That's also a possibility.
I bought a Corolla OEM radio with GPS and XM radio go my 4Runner. All I need to finish the install is connect the radio to the VSS and reverse wire. (Reverse wire is for backup camera, VSS is to help keep the NAV accurate) then the T1819 from it will go in my Saturn and I'll fix the fan in mine and give it to my brother for his Saturn.
Old 04-08-2018, 08:57 PM   #282
1996SL11.9L
2002 SL1
Another battery voltage update. My brother has a newish battery from a 2002 we stripped out for parts. His battery voltage after sitting overnight in 26 degree weather was 12.3v. I'm not worried my battery is taking a dump. My car sat 2 days and had the same voltage. Plus the battery voltage-temp chart kind of lines up with what I'm seeing.
Old 04-08-2018, 10:10 PM   #283
That is the expected voltage for time and temp with the nominal parasitic load that is on every modern car. If you use the Optima yellow top it would be 12.5 or so as they run a higher terminal voltage.
Old 04-22-2018, 07:24 AM   #284
1996SL11.9L
2002 SL1
Started using the water injection again. It's set up to use 1 gallon per tank of fuel.
Old 04-22-2018, 07:25 AM   #285
1996SL11.9L
2002 SL1
The other part of the water injection.
Old 04-22-2018, 09:34 AM   #286
Waiex191
Waiex191's Avatar
I am curious. What benefit do you get from water injection? I know it is used for boosted engines for anti-knock and increased mass flow.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 04-22-2018, 01:43 PM   #287
1996SL11.9L
2002 SL1
Same benefits but on a 100hp engine. I use the -20 degree blue windshield wash fluid from Walmart. It also helps keep the intake and combustion chambers clean.
I did this to my 96 that used a qt of oil every 1000 miles. It had so much carbon in the combustion chambers I'd have a cold knock at a cold startup that sounded like a rod was about to smack someone in the back of the head.
I've also seen a minor mpg benefit.
Old 04-24-2018, 10:51 PM   #288
1996SL11.9L
2002 SL1
Well, I have a scraping noise that goes away turning right. Guess it's time to replace the steering knuckle. I have a spare already loaded with a fresh wheel bearing. I'm in no hurry, other than getting it done by Sunday night when I go back to work.
Old 04-26-2018, 04:45 PM   #289
1996SL11.9L
2002 SL1
So I pulled the front drivers side apart and my 5 year old rotors are pop corn rusting from the outside edge into the brake pad area around 1/4". That rust was scraping one of the metal tabs on the stainless steel inserts the pads slide on. So new pads and coated rotors. Also retorqued the half shaft bolt.
Old 04-26-2018, 04:54 PM   #290
Interesting that they would rust like that.
Old 04-26-2018, 04:57 PM   #291
That water injection is darned interesting. I remember reading about that earlier but forgot because I was so busy with other things. Nice setup.
how much of a minor MPG boost did you see?
Old 04-26-2018, 04:58 PM   #292
1996SL11.9L
2002 SL1
I also seen this rust above the drivers trailing arm. This summer I'll fix it. A few of my friends lost their saturns to this rust at the trailing arm mounts.
Old 04-26-2018, 05:01 PM   #293
That could be a real issue.
Old 04-26-2018, 05:12 PM   #294
1996SL11.9L
2002 SL1
Two of my friends lost three saturns for that drag link rot. I'm going to try and fix it this summer.
Do you know if I can cut a good drag link mount area out of a 96-98 and use it to repair my 2002? My friend has my old 96 and a 97 that may have good drivers side areas.
Old 04-26-2018, 05:16 PM   #295
1996SL11.9L
2002 SL1
I'm going to say 1-2mpg which means nothing with how much driving conditions change. I do know that when I use it my ScanGauge mpg is off to the low side. Same when I use acetone. I get a little better than the ScanGauge predected fillup.
Old 04-26-2018, 05:19 PM   #296
1996SL11.9L
2002 SL1
Here is a picture.
Old 05-18-2018, 07:04 PM   #297
1996SL11.9L
2002 SL1
Now that it's in the 60's in the morning and pushing 80 during the day I'm happy seeing this again.
Old 05-19-2018, 08:30 AM   #298
Signmaster
It's hard to beat that kind of MPG return.
I've tried a few times when traffic was light to upshift that early. I just can't bring myself to do it. I think I'd get run over trying it during my normal commute.
Signmaster is online now   Reply With Quote
Old 05-19-2018, 02:54 PM   #299
1996SL11.9L
2002 SL1
I'll admit it's not a strait up tank of gas. 4oz of acetone plus my -20f windshield washer fluid water injection. But, those are minor improvers.
A big torque improver for me was the steel core ignition wires (mag core?) and the dual electrode plugs. On a flat road in 5th at 30-35mph I have no problem keeping up with traffic. My speed limits are either 45-50-55 (depending on which non town rural road. Or 25-35mph depending on which town I'm driving through. Having the spark tables throwing 34 degrees advance at it helps too IMO.
Old 05-30-2018, 04:12 PM   #300
1996SL11.9L
2002 SL1
I've been having the dredded cam sensor code (340) and once a missfire on cylinder 4.
So, yesterday I pulled the plug wire and measured its resistance. Yea, a effing open resistance. All those pulling the boot off and re-crimping the plug end back on must have wrecked it.
Got another set of mag core suppression wires. My old ones were Bosch with a lifetime warranty. So I got the Duracrap Gold in the exchange. (Autozone no longer carries Bosch).
Plugs looked decent for 2 heat ranges colder. 4 plug was dirty. But that's expected with my water injection nozzle located around that cylinder in the intake plenum. I swapped 3 and 4 plug to clean it up.
Shining a light in the plug holes I see aluminum on the Pistons. Center of Pistons have minor carbon buildup. Not *****ing about that with 180,000 miles on engine.
Next is dealing with the rear lower suspension strut rod rust at frame on drivers side.
2002 sc2 b.c.m. piperpilot S-Series Tech 2 11-12-2014 09:34 PM
2002 sl 1 Dee631 S-Series Tech 1 11-04-2014 05:36 PM
2002 SC2/Metra 70-2002 stereo harness issue Kai S-Series Tech 4 12-14-2008 03:41 PM
2002 SL1 Help Please reddragonflys20 S-Series Tech 9 11-21-2006 04:26 PM
2002 Sc2 Sps mle S-Series General 1 07-02-2005 07:33 PM
