Old 03-15-2019, 12:57 AM   #1
JTav8r
JTav8r has a spectacular aura aboutJTav8r has a spectacular aura aboutJTav8r has a spectacular aura about
2001 L-Series 3.0L Wagon
Default LW-300 End-of-the-Line??
The day I knew would come seems to have arrived.
With just over 224K on the odometer, I had a no start condition last Friday evening on my 2001 LW-300. For about 2 years now I have had intermittent P0304 and misfires, especially when accelerating hard (such as merging on to a KS freeway). Had vehicle towed to my mechanic and they discovered (upon removing the intake manifold and conducting a compression check) that the valley was "filled with oil" and 2 cylinders with compressions below 100.
#1 - 145, #2 - 130, #3 - 95, #4 - 127, #5 - 145, #6 - 85
After cleaning the oil out of the valley, cleaning the plugs (just replaced 24K miles ago at the 200K Timing Belt change) and reassembly, the engine would start and run without misfiring or throwing codes.
For what a reman on this L81 engine would cost, I will most likely just replace the vehicle.
It has been just shy of 12 years and 182K miles for me with this one - but it looks like the end of the line.
Add to JTav8r's Reputation
Rate the quality of this post and help JTav8r reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JTav8r is offline   Reply With Quote
Old 03-15-2019, 01:58 PM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: LW-300 End-of-the-Line??
I can relate to your situation. See my post on Engine Swap Time.
Another alternative is to look at a Junkyard engine. There are still plenty of 3.0's in the junkyards with relatively low miles. Personally, I'm much more comfortable with a junkyard engine over a rebuilt one. You never know what type of materials (Usually the cheapest) that were used for a rebuild.
If your car is in good shape, this might be a great option for you.
When I looked at how much an engine swap would cost compared to buying another vehicle, the decision was an easy one. Again, the condition of your wagon now will be a major factor in your decision.
Keep us posted on how you proceed.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 03-16-2019, 10:23 PM   #3
JTav8r
So I decided today that I will not be fixing the Saturn.
I am going to be contacting a local organization that takes donated cars and either fixes them or sells them to help pay for repairs to others. They then provide these cars to veterans in the community that are in need of a reliable car.
So there may still be some life in her yet - we will see.
It was just short of a 12 year party as a Saturn owner. And a lot of the reason it lasted so long was this forum!! Thank you each one that shared your experience and knowledge.
I can only hope to get 12 years and 180K miles out of the replacement car - a 2019 Ford Fusion SE...
Thank you everyone!!
John
Old 04-05-2019, 06:10 AM   #4
L300Dude
L300Dude is on a distinguished road
Replace the ignition modules if u have oil in spark plugs. And clean entire air passageway, intake plenum and upper intake manifold. When the rubber protection around the spark plugs fails to keep oil away your ignition module will spark at ground through the oil and in time ruin it. Nothing is absorbing the electrical spark, no load. It's supposed to go through the spark plugs, the electric current. By it hitting ground through the oil, you will get misfires and oil backing up into the air filter and also damaging your mass air flow/intake air temp sensor (both are in the Mass air flow unit. Also clean the pcv and install new valve cover intake gaskets and clean any visible oil anywhere inside where air travels. Take one full day to get it clean and dry. Vacuum hoses too. The egr and manifold absolute pressure sensor can wait to replace. After this process, your car WILL turn on. If u remove the injectors (very easy) put new seals and oil them up when popping them back in. All those oiled up spark plugs replace them. Forget the fuel pump and filter. They're fine, your anti theft too. I got everything on eBay. Cheap. We got this buddy.
Add to L300Dude's Reputation
Rate the quality of this post and help L300Dude reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
L300Dude is offline   Reply With Quote
2008 VUE Red Line and Green Line Info and Photos Charlie 2008 Vue 26 12-15-2018 09:59 PM
Fuel Line Supplier?-pressurized line is leaking Reliabilityman S-Series Tech 1 05-06-2015 12:31 PM
Lower trans line removal, luckly the metal line didn't twist Jeeprz! S-Series Tech 4 01-23-2015 12:58 PM
Can't decide between a Green Line and Red Line? tackepj Vue Green Line 0 03-15-2010 08:16 AM
Uh Oh! VUE Red Line Fuel Line Recall CanVueYes! Vue Red Line 6 06-26-2004 05:03 PM
