Old 12-29-2004, 01:15 AM   #1
nkyleft
nkyleft is on a distinguished road
nkyleft's Avatar
Default won't shift into gears
Well I have manual 92 sc with 135k miles on it. It's nearly impossible to shift gears...I assume my transaxle is busted. How much to replace that and any other ideas?
Add to nkyleft's Reputation
Rate the quality of this post and help nkyleft reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nkyleft is offline
Old 12-29-2004, 05:21 AM   #2
wolfman
wolfman's Avatar
Default Re: won't shift into gears
A better description of the exact problem you are having would be of a great help....It could very well be something simple. (Never assume anything)
Add to wolfman's Reputation
wolfman is offline
Old 12-29-2004, 02:53 PM   #3
nkyleft
nkyleft's Avatar
Ummm well I've noticed it's been much harder to shift the car into gear....but I was still able too. We just had 10 inches of snow and 0 degree weather so i figured it was just cold. Last night driving home it was nearly impossible to shift gears. Today I went out and tried and I can't get the car in any gear. Sounds like the transaxle to me. Thats about it. It's a manual.
nkyleft is offline
Old 12-29-2004, 03:13 PM   #4
Razorbak
Razorbak's Avatar
Or it could simply be a problem with the linkages between the gearshift lever and the cables or the cables and the transaxle.
If you look down between the air intake snorkle and the brake master cylinder with the aid of a flashlight, you can see the cable connections to the transaxle down on the driver's side in the rear of the engine bay. Are those cables still connected? Do they still have their clips in place?
Transaxle cables
If you can't see them, it might help to remove the air intake snorkle between the throttle body and the air filter box.
Add to Razorbak's Reputation
Razorbak is offline
Old 12-29-2004, 04:00 PM   #5
nkyleft
nkyleft's Avatar
From what I can tell the cable look good and in shape with clips and everything. They look like the ones in the picture
nkyleft is offline
Old 12-29-2004, 04:03 PM   #6
Razorbak
Razorbak's Avatar
It it hard to shift the cable, like something on the end is binding, or does the shift lever float pretty freely, but feels like it's disconnected?
I'm trying to isolate the source of the problem between two potential locations: (a) the cables/connectors, or (b) the transaxle assembly itself.
(There are still more connectors than the ones you just located, but they are a little harder to examine since they are under the shifter housing.)
Does it shift easily when the engine is off? Does it only present resistance when the engine is running?
Those last two questions might help isolate a potential problem with the clutch itself.
Razorbak is offline
Old 12-29-2004, 04:14 PM   #7
nkyleft
nkyleft's Avatar
1. Shift the cable? Do you mean I should go wiggle the cable the cable itself?
2. It shifts easily when the engine is off and when the clutch is not depressed and pressed. Yes, only when the engine is running is it impossible to get the car in gear.
If it's the clutch I'm not going to replace it bc it would cost more than the blue book value of the car.
nkyleft is offline
Old 12-29-2004, 05:25 PM   #8
Razorbak
Razorbak's Avatar
Sorry, I meant is it hard to shift the lever, like something on the end is binding, or does the shift lever float pretty freely, but feels like it's disconnected? If it floated freely and felt disconnected, then that would indicate a cable connection problem undeneath the shift housing.
Sounds like you have a clutch problem, and not a transmission problem per se. Do you have access to a set of tools, and are you mechanically inclined? Do you have any friends that are handy with tools and might be willing to do you a favor or work for a couple of cases of beer?
If so, then the parts for a Saturn clutch replacement are only about $130 from ClutchCity.com. The labor is the most expensive part of the repair.
Razorbak is offline
Old 12-29-2004, 05:28 PM   #9
nkyleft
nkyleft's Avatar
Well I'm not the best mechanic but I have done a few things to my car. Installed my injen intake, replaced the fuel filter myself, pcm, ects.....clutch might be too much for me.
Thanks for the help.
My dad think it's time to get a newer car. Time to go shopping.
nkyleft is offline
Old 12-29-2004, 07:05 PM   #10
sherlock.holmes
sherlock.holmes is on a distinguished road
2004 ION Red Line
I had this problem about a year ago with my 94 Saturn SC2. Took it to the dealer because I don't trust most mechanics with drivetrain problems. Anyway it turned out to be a soleniod on the hydrolic clutch that had been leeking and needed to be replaced. At the dealer it cost about $350 to have it fixed and the clutch has been fine ever since. I should also mention that I now have over 192k miles on the original clutch.
Add to sherlock.holmes's Reputation
Rate the quality of this post and help sherlock.holmes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sherlock.holmes is offline
Old 12-29-2004, 07:48 PM   #11
Razorbak
Razorbak's Avatar
Actually, the hydraulic system for the clutch is pretty easy to replace (a lot easier than the clutch itself) and you can probably find a used one at a junkyard for just a few bones. If that is indeed the problem, then this might be a relatively inexpensive DIY project.
Razorbak is offline
Old 12-30-2004, 12:47 AM   #12
Like Wolfman said a better description of the problem is in order.
Hard to go into gear only with the engine running Most likely not an internal problem to the trans.
Where is the clutch pedal engaging the clutch? Low on the pedal or high on the pedal? Does the pedal feel normal? Easy smooth operation?
Add to ssicarman's Reputation
ssicarman is offline
Hard shift upper gears... marc7242 S-Series Tech 0 05-26-2009 08:46 PM
Sometimes hard to shift gears... jk3006 S-Series Tech 10 02-04-2009 11:54 AM
No Clutch Pedal: But will shift gears?? TIMSPEED S-Series Tech 2 10-08-2007 12:38 AM
My Auto Tranny Doesn't Shift...it Slams Between the Gears dandydan S-Series Tech 21 04-25-2007 03:27 PM
My 96 SL revs high when you shift it into higher gears paumcd S-Series General 6 03-22-2007 04:51 PM
