Old 09-16-2018, 02:58 PM   #1
gveinot
gveinot is a jewel in the roughgveinot is a jewel in the roughgveinot is a jewel in the roughgveinot is a jewel in the rough
gveinot's Avatar
2000 SL2
2000 SL2
Default S Series Automatic pulling forward at idle
A while back I posted an issue in which our 2000 SL2 automatic ( now 450,000 km ) was creeping forward at idle while in drive, 2nd, or reverse. The issue was worse when the engine was cold on first start and once warmed up the issue was less noticeable. At cold start the car would literally go 20km/h and shift into second gear. You had to hold quite a bit of pressure on the brake to keep it stopped. The issue was never idle speed, that was normal. The cause was the TAAT valve body. I swapped it today and now everything is normal. This was an interesting one as this valve body shifted perfect and the fault I described would disappear once the engine was warmed up for more that 10 minutes. I'll post more details on the condition of the solenoids later in this thread. I hope this post helps someone else out down the road.
Add to gveinot's Reputation
Rate the quality of this post and help gveinot reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gveinot is offline   Reply With Quote
pulling away at idle when cold gveinot S-Series Tech 15 09-17-2018 07:06 PM
Automatic transmission going forward in reverse and shift clunk into 2nd gear john92saturn S-Series Tech 9 05-29-2016 08:05 PM
rougher idle in forward than reverse blue92 S-Series Tech 0 04-27-2012 03:22 PM
SL1 fast idle until stop forward travel polrb S-Series General 8 11-24-2005 05:32 AM
S Series Automatic SMF007 S-Series Tech 8 08-23-2001 02:33 PM
