Old 08-25-2011, 07:12 PM   #1
slacke
slacke is on a distinguished road
Default 2006 Saturn Vue Blower Motor Totally Inop
This is giving me fits. Blower motor inoperative. I test the motor with 12 volts and it runs fine. Blower fuse has power both sides. HVAC relay is working. Control switch is operating normal as far as I can tell. (When you switch it to off it cuts off the A-C compressor.) Could it be the resistor? Any ideas? Thanks in advance, Slacke.
Add to slacke's Reputation
Rate the quality of this post and help slacke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slacke is offline   Reply With Quote
Old 08-25-2011, 09:08 PM   #2
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
Default Re: 2006 Saturn Vue Blower Motor Totally Inop
See post # 4 of following thread for wiring diagram (its good for 2006):
http://www.saturnfans.com/forums/sho...d.php?t=144044
The blower bypasses all resistors when you select position 4.
Most likely cause of not operating at any speed is a overheated (and now open) connection in the 40 amp blower +12 feed line.
See the diagram - many have found overheated/corroded connections in the C200 connector which is behind the close-out panel next to drivers left foot when seated (panel behind hood release).
The panel is part of the carpet / door sill retainer. It can be removed by sliding a putty knife or screwdriver underneath and gently working it up.
You may want to take a peek behind the panel. If the larger orange wire has black and bubbly insulation - you could cut a chunk out and splice in a new piece to bypass the connector.
I try to visit forum daily but suggest you use private messages if in a rush (comes to cell) and include email address for extracts. I seldom check visitor messages so please don't use.
Old 08-26-2011, 05:23 AM   #3
slacke
Thanks Grumpy! That makes sense to me. I will check it out today and report back.
Old 08-26-2011, 08:41 PM   #4
slacke
Well Grumpy, you were right. I have the blower running again. I pulled a bone-head manuver and cut the wrong orange wire so I got to splice two wires tonight. I never would of found that in a hundred years. Once again, thanks.
Old 08-26-2011, 10:44 PM   #5
far2grumpy
far2grumpy's Avatar
2005 VUE 3.5L
2007 VUE 3.5L
You only cut one wrong wire? That hardly qualifies as a mistake in my book.
I've been known to build a 24 wire harness and wind up with the whole thing about 18 inches too short. It was painful and pitiful to see how I paid for that.
Its good you have the blower working again - there's a bit of chill in the air in Iowa so we'll soon forget about the A/C and start checking to make sure the heated seats still work.
Old 06-30-2013, 06:36 PM   #6
gonna.act.right
gonna.act.right is on a distinguished road
Just note: I found this thread after the same issue has come up on my '07... I appreciate the diagram, but just want to add my findings and assist others with it...
On the blower motor resistor, after pulling the plug and turning the click facing towards me... my colors are the same as the schematic, but pin outs are different... instead of (lft to rt)Yel,TN,L-Blu, Pur.. Mine is Yel,L-Blu, Pur,TN... And my VOM readings show increasing or decreasing resistor values; depending on how you want to look at it; but do relate to the diagram as more resistance slows the motor down... on the pur branch those 2 resistors equal .6 Ohm, the resistor between L-Blu &TN is 1 ohm, and between TN & Yel is 1.7 and total I got 3.3 Ohms.. So aside from the these values being incorrect, I know I have no open circuit and I should be good to continue...
As far as the orange wire at c200, again, great help on the pointer... I checked voltage on both sides of the plug and had 1.5vd.. So I am going to splice the connection & bypass the connector with fuse link wire. Hopefull this will restore ample power to my blower, as I was only getting 11.2v at the blower motor...
PS: if you ever need help troubleshooting & don't mind spending $15 for your vehicle... The DYI version of the software shops & garages use is available... alldatadiy [dot]C0M Which is where I'm going if this c200 doesn't do it...
Add to gonna.act.right's Reputation
Rate the quality of this post and help gonna.act.right reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gonna.act.right is offline   Reply With Quote
Old 07-09-2013, 04:31 PM   #7
gonna.act.right
Hey guys....
BINGO!!
Popped the panel, lifted the harness from the body clips & seperated the plug.. Sure nuff, saw a burnt spade from one side of the plug... That's the wire that I spliced and cold air again!!!
Old 08-28-2013, 07:42 PM   #8
travisp864
travisp864 is on a distinguished road
travisp864's Avatar
2004 VUE 3.5L
Same thing here. Orange wire in that connector totally burned the terminal. 2004 AWD V6.
Add to travisp864's Reputation
Rate the quality of this post and help travisp864 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travisp864 is offline   Reply With Quote
Old 07-19-2014, 11:37 AM   #9
WannaHelpU
WannaHelpU is on a distinguished road
Found the connector behind the plastic panel just as f2grumpy described.
Before looking here, I checked the manual/fuses, etc. Funny, but the manual didn't say anything about the possibility of a corroded orange wire... go figure.
I was lucky. Separated and re-connected the connector and that did it; no splicing necessary... whew!
Thanx, grumpy!
Add to WannaHelpU's Reputation
Rate the quality of this post and help WannaHelpU reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WannaHelpU is offline   Reply With Quote
2006 Saturn VUE V6: Changed motor mount, still getting vibration & MORE! mustud79 Vue Tech 18 02-26-2017 06:06 PM
2000 saturn ls2 blower motor how to?? omgwtf L-Series Tech 1 11-22-2009 12:35 PM
2004 saturn vue , ac/heat blower motor no power iamyourtech Vue Tech 3 09-08-2009 10:40 PM
2006 Vue blower motor replacement NoCheese Vue Tech 13 08-22-2009 08:36 PM
Blower motor inop Nick3saturns S-Series Tech 6 04-01-2007 11:49 PM
