Old 06-23-2012, 09:18 PM   #1
bsplhcb
bsplhcb is on a distinguished road
1996 SL2
Default 1995 Valve cover piece broke
I got a 1995 aluminum valve cover to replace my 1996 composite cover. Inside the cover are a couple black vents that extend downward. When I was cleaning it up a piece of one of those vents broke off in a V shape right in the middle.
Is this going to cause problems? Can I still use this?
Add to bsplhcb's Reputation
Rate the quality of this post and help bsplhcb reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bsplhcb is offline   Reply With Quote
Old 06-24-2012, 06:30 PM   #2
OldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud ofOldNuc has much to be proud of
Default Re: 1995 Valve cover piece broke
Probably, not optimum but should be useable. Watch for oil being sucked into the intake. If it seems excessive then it is the broken vent. The issue shows up as excessive oil consumption greater than previously noted.
HELP! 1995 SL2 Valve Cover Gasket! ach95 S-Series Tech 13 08-22-2008 04:06 PM
97 Saturn SL2 Valve Cover Broke Metal Piece Came Through top jkrettlen97SL2 S-Series Tech 7 05-05-2008 11:15 AM
FS: Cam/Valve Cover from 1995 DOHC - $30/shipped delturcious Old Classifieds 1 07-29-2006 03:55 PM
Piece of valve cover gasket.... Tom92SCm S-Series General 2 09-18-2005 05:43 PM
DOHC Valve Cover Gasket Replacement on 1995 SW2 el bon bon How-To Library 5 02-22-2005 06:07 AM
