Old 01-13-2018, 02:15 PM   #1
Mike1961
Mike1961 has a spectacular aura aboutMike1961 has a spectacular aura aboutMike1961 has a spectacular aura about
Default Problems with cooling 03 Saturn Vue 3.0L
I have posted before regarding the problems I am having with an 03 Saturn Vue with a 3.0L engine. Radiator was replaced recently because Trans cooler ruptured. We have flushed many times because of all the "junk" in the cooling lines, heater core etc. Almost running clean now, but I continue to have problems with the car shutting off when temp goes slightly over 1/4 on temp gage. In addition, the fan does not want to turn on when it seems it normally should. Yesterday, after multiple additional flushes, we cut the air conditioner on to heat up the vehicle more quickly. Fan cut on at slightly over 1/4 where the car has previously turned itself off. Car kept running and all seemed well. Then I decided to turn the air conditioner off and the car immediately turned off as soon as I turned the air conditioner off. Not sure what is going on with that...any thoughts?
Add to Mike1961's Reputation
Rate the quality of this post and help Mike1961 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mike1961 is offline   Reply With Quote
Old 01-14-2018, 02:09 PM   #2
Default Re: Problems with cooling 03 Saturn Vue 3.0L
Ground, battery, battery cables/connections issues?
cooling problems Cory S-Series Tech 7 04-16-2012 05:06 PM
cooling fan problems Reverend Jones Vue General 0 11-03-2008 12:05 AM
Cooling fan problems s351saleen S-Series Tech 8 10-04-2006 05:28 PM
Help! Cooling Problems sat96 S-Series Tech 32 11-01-2003 02:36 PM
cooling problems lweber General Saturn Discussion 3 04-17-2003 08:51 AM
