Old 07-03-2006, 01:52 PM   #1
Luke
Luke's Avatar
Default 95SL2 PCV square cornered "S" shape Hose cracked
In failing to find anything in the "How-To" Library, something tells me that someone (((>it was probably Wolfman <))) had written that when replacing that 'hose', one should not us a fuel line hose.
I'm asking if I can use this for now, as I'm unable to actually pick up the squared cornered "S" shaped PCV hose unit; For I have a 7.9mm ID (((>inner diameter<))) hose, which I'd like to use.
Comments from anyone
Luke is offline   Reply With Quote
Old 07-03-2006, 03:13 PM   #2
Sky King
Sky King's Avatar
Default Re: 95SL2 PCV square cornered "S" shape Hose cracked
Why can't you use a hose compatable with the fuel system? I too am curious. A hose compatable with the fuel system would be compatable with petrolium. The PCV is venting vapors that have oil and other blow by gasses which are petrolium based. So why wouldn't you want a hose that is compatable with these products?
Other than that I guess you need to go to a auto parts store and ask for vacuum hose. It may be hard to find in that size.
Old 07-03-2006, 03:32 PM   #3
I would just make sure it's not a material that's gonna collapse under the vacuum from the manifold (it's pretty strong).
Old 07-03-2006, 03:44 PM   #4
Luke
Luke's Avatar
The hose material and size I'm planning on using, will definitely, and said with considerable confidence, NOT collapse.
As I indicated, my concern that there was a reason for only using a hose designed specfically for the PCV gas/fumes.
(((>Remember you all, I'm still required to stay ON the turnip truck, I can asked these type of questions. <)))
Old 07-03-2006, 03:49 PM   #5
BarnOwl
BarnOwl's Avatar
Odd...my memory is exactly opposite yours. I seem to remember a post from Wolfman saying it was okay to use fuel hose. Just make sure it doesn't kink.
Old 07-03-2006, 04:10 PM   #6
96GSL1
96GSL1 is on a distinguished road
96GSL1's Avatar
1996 SL1
That's it. It's such a short hose with just enough of a bend to it, it's hard for some plain cut hose to conform. I think I picked it up (preformed) at Saturn for $2 and change.
96 SL1 202k
98 Windstar 123k
96GSL1 is offline   Reply With Quote
Old 07-03-2006, 05:27 PM   #7
Luke
Luke's Avatar
Keep in mind, I'm referring to the hose unit, which handles the PCV.
Old 07-03-2006, 06:47 PM   #8
wolfman
wolfman's Avatar
You got it backwards Luke...I actually recommend using fuel line hose as a less expensive option to replace the PCV line vacuum hose. (Sold by the foot at most autoparts stores)
Old 07-04-2006, 03:22 PM   #9
Luke
Luke's Avatar
> Wolfman < Thank you for the alert. What I did earlier this morning was to replace the PCV Hose set-up with the hose that actually is used running from the right top side of the vavle cover over to the air intake. It's a pre-formed squared cornered "S" shaped. I had an extra one, and it fits rather well -- not perfectly, but it's better than the cracked unit I took off.
I should note, I was planning on using a fuel line for a temporary set up, but found that my line was just a little too tight -- 7.9mm ID. I'm sure it would have fit, but I just want to get a correct hose.
I'll do that on my drive back home tomorrow afternoon, as I drive by a PepBoys, as well as a Kragen, both of which I visit regularly.
Old 07-04-2006, 05:40 PM   #10
eljefino
eljefino's Avatar
1995 SW1
I recommend actually going to a napa or carquest, as they're more likely to sell by the foot. Consumer type auto parts stores will give you a blister back of 6 feet of hose, what will you do with the rest?
7.9mm? huh? Back east we use 3/8" (slightly tight) or 13/32" (just right but hard to find). They sometimes call it "emissions hose" and the cooler stores you can see the different reels of what they have.
When you route it, give yourself some slack and gentle bends-- don't try to recreate the tight corners of the stock piece. Tight corners are crimp & kink opportunities. You can always route it and cut another inch off if it's not working right yet.
Whatever you do don't waste gas chasing a 50 cent discount on hose either.
Old 07-04-2006, 08:07 PM   #11
BarnOwl
BarnOwl's Avatar
While many parts stores have fuel line in blister packs. I've yet to see one that didn't sell it by the foot as well.
Old 07-05-2006, 10:12 AM   #12
Luke
Luke's Avatar
Default Re: 95SL2 PCV Hose at Cam Cover, rubber corner cracked
> El Jefino <
I'm very sensitive to that issue, for I'm going to just "circle the hosing around; There will be no kink possible.
(((>By the way, it's offically called the "PCV hose at cam cover" <)))
Old 07-05-2006, 12:09 PM   #13
Luke
Luke's Avatar
Actually the correct hose measurement would be 9.5mm ID. It's perfect, but, the one I have is simply too short.
Old 07-05-2006, 12:38 PM   #14
amazinghl
The napa, checker, and autozone near me sell them by the inches.
00 Insight 72mpg
Old 07-05-2006, 07:55 PM   #15
eljefino
eljefino's Avatar
1995 SW1
I correct myself, its 11/32 not 13/32".
But 3/8" won't do you wrong.
Old 07-06-2006, 09:52 AM   #16
Luke
Luke's Avatar
Yesterday, on the way home, I picked up a 3' length of 3/8 [10.0 mm] hose. Working perfectly; Will allow me time to see if I can go back to the original set up. Not that important, but I'm in to keeping things as close to original as possible.
Cracked PCV hose - would that cause a vacuum leak? acr2001 S-Series General 5 03-13-2014 09:38 PM
How should I repair a cracked PCV valve hose. oseberg S-Series Tech 13 11-25-2007 05:28 PM
Left Transmission "Shear" Cracked modnemo L-Series Tech 1 05-23-2007 11:22 PM
Mountain driving in "3" gear setting (95SL2) Automatic Luke S-Series Tech 8 07-18-2004 09:36 AM
"Genuine" PCV valve and what's up with Fram? Richard S-Series General 5 01-28-2004 06:37 PM
