Old 05-08-2006, 02:10 PM   #1
colosat
colosat is on a distinguished road
Default Using E-85 in my 1994 Sat Sw1
I am using 2 gallons of E-85 per fill-up.
According to en.wikipedia.org/wiki/e85,
up to 20% E-85 is not harmful in post-1988
vehicles. What do you say?
colosat is offline   Reply With Quote
Old 05-08-2006, 02:41 PM   #2
K-1
K-1 is on a distinguished road
K-1's Avatar
2008 Astra XR
Default Re: Using E-85 in my 1994 Sat Sw1
Saturns are definitely fine with up to 10% ethanol. Most states use that instead of MTBE as the winter additive. Though 20% of E-85 is 17% ethanol, which isn't specifically listed as being safe, but may be okay. Anyone can edit a wiki page, so take everything on wikipedia with a grain of salt.
Toyota: Moving Forward... off a cliff at a high rate of speed.
K-1 is offline   Reply With Quote
Old 05-08-2006, 03:01 PM   #3
Gerry Proctor
2008 Astra XR
2008 SKY Red Line
It's hard to predict the outcome once alcohol levels exceed a 10 percent mix since every vehicle will have a different reaction. Don't be surprised if your MIL comes on due to a lean condition at the O2 sensor under heavy throttle conditions. That blend is within the capacity of your fuel system, but not by much. I doubt that you'll suffer any fuel system consequences, like materials deterioration in that low of a blend.
Old 05-08-2006, 04:52 PM   #4
amazinghl
Don't use it more than what your owner manual recommands.
00 Insight 72mpg
Old 05-08-2006, 04:58 PM   #5
Eco-Mod
Eco-Mod is on a distinguished road
2006 ION Red Line
2007 SKY
Do not use greater than 10% ethanol in any vehicle unless otherwise specified. Having greater than that amount causes some gaskets and plasics to swell, as well as destroys fuel injectors. On another note, you are losing fuel economy as well as power with ethanol. The best fuel mileage and power will come with the fuel with the least or no ethanol.
'06 Ion RedLine
Red Comp. Pkg.
Too Many Mods To List!
260+ whp 240+ wtq
'03 Ion 3 (Retired)
Eco-Mod is offline   Reply With Quote
Old 05-09-2006, 05:38 PM   #6
colosat
does anyone have technical or practical
experience that @23% ethanol blend is dangerous
to my vehicle, re: gas tank, fuel lines, injectors, catalytic converter?
I am just asking in the context of the wikipedia article.
I believe ethanol may produce acids in certain cases, requiring
anti-acid oil, and engine-hardening additives.
Brazil I believe allows 25% ethanol blend at pumps now.
I am not criticizing anyone here....
Old 05-09-2006, 07:22 PM   #7
There are a number of US-built, US-sold production cars and trucks that run fine on anything between pure gasoline and E-85. Do they need special oil? I presume their fuel systems are made of materials that are made for this range of fuel mixture.
Old 05-11-2006, 10:19 AM   #8
carlb
carlb is on a distinguished road
1994 SW2
Colosat,
I don't know what will happen if you use E-85. I use it whenever I can get it, usually on weekends in Cheyenne, WY. I fill the tank and go. The car, a 94 SW2, runs great, no lights, no misses, a little less power. MPG a little less, from 35 to 27, and it smells funny. Cost per mile is about the same. Does it hurt the car? I don't know. I'll let you know if it breaks (I don't expect it to). I have run about 800 miles on the stuff. Yeh, and it probably voids your warranty!
carlb is offline   Reply With Quote
Old 05-11-2006, 10:27 AM   #9
K-1
K-1's Avatar
2008 Astra XR
E-85 WILL corrode your fuel system if the vehicle isn't designed to use it. DO NOT use straight E-85 in S-series Saturns.
Link to TSB
Old 05-11-2006, 10:57 AM   #10
poorboy
poorboy is a jewel in the roughpoorboy is a jewel in the roughpoorboy is a jewel in the rough
and never take wikipedia.org as the truth...
94 SL2 Automatic
poorboy is offline   Reply With Quote
Old 05-11-2006, 09:26 PM   #11
DecayingOmega
DecayingOmega is on a distinguished road
Most gas sold in the U.S. already contains 10% ethanol.
DecayingOmega is offline   Reply With Quote
Old 05-11-2006, 10:15 PM   #12
PlasticCarsRock
PlasticCarsRock's Avatar
I don't know how much this applies, but in vehicles that can run on ethanol alone, there is a 10% drop in efficiency and a 5% increase in power from running on ethanol (as opposed to regular fuel).
The increase in power may come from the higher octane rating of ethanol, thus, it might not increase your power (maybe even decrease it). Like I said, I'm not really sure how this applies to you.
Old 05-12-2006, 03:45 AM   #13
Bigdaddy94sc2
Bigdaddy94sc2's Avatar
2006 ION-2 Sedan
Link to TSB
Exactly!
If you have been running it already, I would change your Fuel filter and run some Techron fuel system cleaner with some "spirited" driving to try to get as much of that out as possible. I had a customer come in that bought E85 gas without even knowing it (or caring) about 3 months earlier. It wreaked HAVOC on the sytem once it went back to normal gasoline. Almost the ENTIRE fuel system rusted out from the INSIDE out! I had to repalce the fuel pump/sending unit, thoroughly clean fuel tank, replace all Fuel lines, replace fuel filter, and fuel pressure regulator, and clean thoroughly, and I mean thoroughly the fuel rail and injectors. Took almost 2 days worht of work due ot the cleaning, and cost the customer almost $2500. E85 in normal systems is highly corrosive to say the least.
Old 05-12-2006, 12:28 PM   #14
This is what I don't get, though. What's so "normal" about that? Agreed, our S-cars are NOT tolerant of E-85, as are, apparently, most gas cars. But those that do run on E-85 aren't any more expensive than their gas-only counterparts. Their fuel systems are obviously made from different materiels, but they can't be much more expensive materials. So why aren't more cars built to be more fuel-flexible? Or is this, ultimately, a political question that's "beyond the scope"?
Old 05-12-2006, 01:17 PM   #15
Luke
Luke's Avatar
Default Big Daddy's alert
> Big Daddy 94 sc 2 <
If you have been running it already.......................
Appreciate the alert
Luke is offline   Reply With Quote
Old 05-12-2006, 02:40 PM   #16
Bigdaddy94sc2
2006 ION-2 Sedan
Default Re: Big Daddy's alert
He said he has been, so I simply stated "if they already have" to warn other drivers at the same time.....
Old 05-12-2006, 05:21 PM   #17
eljefino
eljefino's Avatar
1995 SW1
E-85 cars get a substantial CAFE exemption.
Ford taurus FFV (flexible fuel vehicle) is a popular example.
The government gives them a HUGE loophole as motivation to develop the technology. The car counts as like 70 mpg on their CAFE average.
Ford subsidizes the price of the FFV junk in their taurus so they can sell more gas guzzlers.
The joke, and it is a cruel one, is most FFV taurii are sold in states where you can't even get E85, so they run regular gas.
converting my 1994 sw1 to run on e-85? bucky katt S-Series Tech 20 12-08-2009 12:02 AM
Thinking about buying a 1994 SW1 justintime S-Series General 5 08-09-2009 05:00 AM
1994 SW1 SOHC O2 Sensor Question brettkramer S-Series Tech 0 08-08-2008 07:09 PM
1994 SW1 rear gate question CDN93SC1 S-Series Tech 1 01-09-2008 09:45 PM
1994 SW1 no start CDN93SC1 S-Series Tech 19 12-06-2007 11:25 AM
