Old 03-22-2020, 04:38 PM   #1
Hiisi
Hiisi is on a distinguished road
Hiisi's Avatar
Default Rear suspension bolts
Hello, folks.
Where could I order bolts and nuts for rear suspension? Specifically, I'm looking for those attaching the lateral links (front and rear) to the crossmember, those attaching strut assemblies to knuckles and also nut on trailing arms.
Hiisi is offline   Reply With Quote
Old 03-23-2020, 08:36 AM   #2
Default Re: Rear suspension bolts
Unless someone can point to GM parts online still stocking parts usable on other vehicles, you're left to scrounge junk yards and eBay. Most suspension hardware are heavily plated against corrosion for virtually the life of a vehicle, galvanized zinc coating. https://www.belmetric.com/ and https://www.boltdepot.com/Metric_tap...m_x_1.5mm.aspx are two places to shop. You'll need to know dimensions.
Old 03-23-2020, 09:50 AM   #3
Hiisi
Hiisi's Avatar
Thanks for your response. Those bolts are extremely rusty. I'm afraid I will have to cut them to replace the suspension. I don't have picture of those at the crossmember but they are even worse.
Old 03-23-2020, 10:39 AM   #4
'Dats some severe rust. Before attacking them with cutting (cutoff wheel?), maybe a dose of PB Blaster can break free the artificial loctite using a pneumatic wrench or long prybars. Manually wrestling rusted nuts and bolts may work by loosening and tightening to break the rust bond while letting penetrant seep in.
Old 03-23-2020, 11:09 AM   #5
Hiisi
Hiisi's Avatar
That's gonna be a serious battle!
I have found these GM part numbers:
10 - 21010276
9 - 21010929
8 - 21011066
28 - 21011888
32 - 21011478
35 - 21010362
36 - 11516074
File Type: jpg WhatsApp Image 2020-03-23 at 10.48.23.jpg (56.4 KB, 7 views)
Old 03-23-2020, 11:35 AM   #6
Waiex191
Waiex191's Avatar
The big nuts and bolts are usually easier to undo than the small ones. I'd use generous amounts of PB Blaster and go wild with the propane torch on that nut. Use 6 point sockets.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Old 03-23-2020, 11:43 AM   #7
SRGW
1997 SL1
Post Re: Rear suspension bolts
I was able to get front control arm bolts from BOLT DEPOT.COM. You need to know size parameters of the originals.
1995 SL1 236,300 2005>2018
1997 SL1 82,000 2014>????
CHECK YOUR OIL!!
Old 03-23-2020, 12:17 PM   #8
Hiisi
Hiisi's Avatar
My worry about getting replacement bolts is that hardness might be unknown.
Old 03-23-2020, 12:30 PM   #9
Waiex191
Waiex191's Avatar
I've sourced large grade 8 bolts from Fastenal before. Otherwise the junkyard is a good source.
Edit: grade 10 metric bolts.
http://www.saturnfans.com/forums/sho...&postcount=179
Edit again:
Boltdepot has class 10.9 metric bolts. They have a tensile strength of 1040 mPa, which is about 150ksi. For reference normal aircraft AN hardware is 125ksi, and the NAS stuff is 150ksi. Just make sure you get the right shank length.
Bryan Cotton
Old 03-23-2020, 12:43 PM   #10
454cid
I'm usually disappointed with Fastenal's selection. When I needed to purchase bolts I ended up ordering from McMaster-Carr.
All the fasteners on these Saturns rust much more than bolts on my Chevy truck.
1999 Chevy K3500
Old 03-23-2020, 12:47 PM   #11
SRGW
1997 SL1
My front bolts are 10.9 hardness and I am sure the ones you are replacing are the same. Bolt depot had that hardness spec.
CHECK YOUR OIL!!
Old 03-23-2020, 12:47 PM   #12
454cid
Those don't look that bad to me. Do you have a bench grinder that you can mount a wire wheel? I think those may clean up pretty well.
Warning: if you're not used to using a wire wheel, definitely wear safety glass.... they will throw wires. Even the industrial grade wheels will throw wires.
1999 Chevy K3500
Old 03-23-2020, 12:57 PM   #13
Hiisi
Hiisi's Avatar
I was thinking of electrolysis if anything can be unscrewed there...
Old 03-23-2020, 01:02 PM   #14
I've taken apart worse, without heat. May not have been "factory safe in a crash" to reuse but they torqued up fine.
I'd go with Fastenel for replacement bolts. They don't have to be 100% matching on length, shaft end style and head size's as long as the hardness and shaft diameter match.
Old 03-23-2020, 01:50 PM   #15
Waiex191
Waiex191's Avatar
I would not want the threaded section bearing load in shear. To long of a shank can be handled with washers.
Bryan Cotton
Old 03-23-2020, 01:51 PM   #16
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
This bears repeating.
The temptation to go crazy-go-nuts with an impact wrench right away is strong, but PB Blaster and manually wrestling them by tightening and loosening can yield suprising results if you can be patient.
Goggles Pisano is offline   Reply With Quote
Old 03-23-2020, 02:29 PM   #17
I bought caliper mounting bolts in the correct grade from one of the two fastener places. They have graded bolts for strength. I presume they have graded nuts to match. I wouldn't put a link to them if I knew they wouldn't match the originals.
Old 03-23-2020, 06:05 PM   #18
454cid
I'm not sure if it's internet lore, or real, but I'd research hydrogen embrittlement due to electrolysis before using it on hardened bolts.
1999 Chevy K3500
Old 03-23-2020, 06:55 PM   #19
Hiisi
Hiisi's Avatar
This is what I have prepared for those screws. First will try to unscrew them. If it fails - cut!
Old 03-23-2020, 07:22 PM   #20
Hydrogen embrittlement was discovered when large construction projects revealed weakened structures in steel used in supports for buildings exposed to the atmosphere like external steel in buildings and bridges. With virtually every bridge requiring rust preventative treatments, painting exposed steel lessens and reduces corrosion and structural weakening from this little known hydrogen embrittlement process occurring naturally. A documentary on tv revealed this phenomenon affecting one building with external steel going untreated. When periodic testing was performed, it was discovered serious weaknesses occurred with bolts used to hold steel together. Mechanical engineers studied it and came up with replacement as a near term solution (costing millions) and coating to reduce infiltration frome exposure.
A search of plating processes seems to explain cleaning preparations may induce embrittlement in certain plating procedures as well as after plating. I think mechanical engineering has this covered long before consumers buying replacement nuts and bolts have any concerns about degraded hardware used in suspensions.
Tags
rear suspension
Rear Subframe Through-bolts AlexofNazareth S-Series Mods 1 05-28-2015 12:58 AM
Rear Camber Bolts? tcndeb Vue General 2 06-20-2013 05:26 PM
Rear camber bolts? TITO Vue General 4 09-22-2009 06:20 PM
Suspension top bolts huttondh Astra Tech 0 09-01-2009 12:00 PM
Rear lateral link bolts... Craig S-Series Tech 3 08-14-2004 11:15 PM
