Old 11-10-2019, 12:39 PM   #1
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
Default Need screw in fitting for water heater hose, dr. side
'96 sc2. I need the heater hose fitting that goes on the intake manifold on the driver side, Anyone have a listing for it on Ebay or Amazon, maybe auto parts store? thanks.
www.bold-fortune.com
sc2dave is offline   Reply With Quote
Old 11-10-2019, 02:01 PM   #2
Default Re: Need screw in fitting for water heater hose, dr. side
Got it out, can you post a picture? I'm guessing it is NPT and you can get a suitable one from even Lowes or Home Depot. At your FLAPS, Dorman is a common brand, look on the Dorman web-site for a match.
Old 11-10-2019, 02:21 PM   #3
Seems like an odd part to fail, which may make it hard to find. It is probably a pipe thread. If you can measure the old one, would be easier to find a replacement. Or grab one from a junkyard. Will probably be free.
Old 11-10-2019, 03:26 PM   #4
sc2dave
sc2dave's Avatar
Originally Posted by billr View Post
Got it out, can you post a picture? .
Ihaven't put a wrench to it, but I'm thinking that it might break off in the manifold. The part that connects to the hose just broke off with finger pressure.
Old 11-30-2019, 05:25 PM   #5
sc2dave
sc2dave's Avatar
anyone have a picture of this?
Old 11-30-2019, 07:16 PM   #6
Is this the intake manifold with heater outlet? If yes, there are threads about it. One video, https://www.youtube.com/watch?v=jtiv4FTcPg4, shows a repair. Other videos are available. Dorman part, https://www.amazon.com/Dorman-902-10...12713976&psc=1.
Old 12-01-2019, 12:03 AM   #7
That's for the craptastic 3rd gen plastic intake manifold. The aluminum intake manifolds have a screw in fitting "hose barb" that threads into the IM while providing a nipple for the coolant hose to slip onto.
I've no idea what the thread is, but I'd hazard a guess that the hose is 5/8" so you'd need a 5/8" barb and try a couple different 5/8" thread styles to see what fits in the intake. Pipe thread tends to be a narrow measure for a given size while straight/compression thread tends to be normal/wide measure.
Old 12-01-2019, 01:00 AM   #8
sc2dave
sc2dave's Avatar
I need one for an aluminum I/M, not plastic.
Old 12-01-2019, 07:43 AM   #9
454cid
Originally Posted by fetchitfido View Post
...Pipe thread tends to be a narrow measure for a given size while straight/compression thread tends to be normal/wide measure.
Pipe sizes are inside diameter. I'd guess it would be 1/2 pipe thread, for a 5/8" hose barb, which seems a bit big for a little 1.9L engine, to me. 1/2" thread is what the V8's use for both the 5/8" and 3/4" lines.
1999 Chevy K3500
Old 12-04-2019, 11:23 PM   #10
TomM96
SC2Dave-
Following 454cid suggestion, if hose diam=5/8 buy two npt hose barb nipples, one with 1/2" npt thread, maybe a second with 3/8" npt nipple.
Then go undercar with wrenches and try to get the old nipple to unscrew.
There's a good chance the hex/thread portion is intact... but you need find out.
If it breaks apart, can maybe remove with a screw thread extractor, or even use various screwdrivers to jam/turn. Worst case, use hacksaw blade & punch/chisel to break apart the threaded sidewall, then prise out fragments....
Clean threads in head of debris(as with tiny wirebrush), thread in the new nipple to check fit....remove , coat threads with Pipe Sealing Compound
install nipple, tighten just more than by hand with wrench, Remove & Repeat to insure the Pipe sealant is on entire threaded bore in head, tighten firmly.
The hosebarb/nipple needs be galvanized steel/iron Not plastic or bronze or brass. Actually Aluminum might be available, and might work... but i'd stick with the original zinc/galvanized steel/iron.
Old 12-05-2019, 09:25 AM   #11
454cid
What is your argument against brass? I've got two brass fittings on my truck.
1999 Chevy K3500
PCV breather hose fitting Claybury S-Series Tech 0 11-01-2016 03:35 PM
3.5L tee fitting for coolant hose RobertGary1 Vue Tech 0 01-13-2016 02:34 PM
'97 SC2 heater hose removal for heater core flush SC2by2 S-Series General 3 10-24-2015 07:03 PM
Cracked fitting-end of overflow hose SL2Many S-Series Tech 4 05-17-2011 09:43 PM
brass fitting near oil cap on valve cover, where does hose go? mikes 1994 z28 S-Series General 1 08-05-2006 02:06 PM
