Old 12-23-2016, 10:41 AM   #1
lmchu
lmchu is on a distinguished road
Dizzy 2005 Vue FWD 3.5 bearing noise
Only hear this bearing type noise after vehicle on the road for a few miles more audible at 40 plus mph slight pitch like air blowing thru a running fan and whirring type sound when slowing down. Took it to a mechanic and they checked both front wheel bearings, power belt, and pulleys all ok. Sounds can drive you crazy. I'm thinking could it be a tire but only after it warms up?
Any thoughts? Thank you in advance
lmchu is offline   Reply With Quote
Old 12-23-2016, 01:14 PM   #2
flyingj
flyingj will become famous soon enoughflyingj will become famous soon enough
flyingj's Avatar
Default Re: 2005 Vue FWD 3.5 bearing noise
I know you said you have a FWD Vue, but what you describe is common problem with AWD 3.5 Vue's. You are describing the textbook sound of the center support bearing on the driveshaft. It squeals like a teapot and can have the vibrational sound while descending.
If you do have an AWD Vue, removing the drive shaft is easy and will quickly confrim if this is your issue.
2001 L-200 2.2l
DOB: 05/08/01 Owned: 07/01/07 to 10/30/18
2006 Vue 3.5L AWD Mileage: 145,000
DOB: 08/24/05 Date Acquired: 12/15/06
2019 GMC Acadia (aka Saturn Outlook)
flyingj is offline   Reply With Quote
Old 12-23-2016, 03:18 PM   #3
lmchu
Dizzy Re: 2005 Vue FWD 3.5 bearing noise
Thanks I should have thought of the teapot sound, that bearing was not checked with the holidays here its tough to get to the mechanics to look hopefully it won't fall off or freeze up on me need the vehicle.
Old 12-25-2016, 12:07 AM   #4
mlc5
mlc5 is a jewel in the roughmlc5 is a jewel in the roughmlc5 is a jewel in the rough
before you go crazy investigating the bearings.. do a quick check of the brake dust shields... I had a similar noise that was driving me crazy... It turned out to be the brake dust shield, rubbing against the rotor.. and I could only hear it when driving around 30 mph or more..
simple fix.. just pry/bend the shield away from the rotor slightly.. and problem is gone..
mlc5 is offline   Reply With Quote
Old 12-27-2016, 05:10 PM   #5
lmchu
Thanks for the tip, had it checked it was not it and also it was not the drive shaft bearing they feel its in the transmission but I'm going for a second opinion.
Old 12-28-2016, 08:35 PM   #6
mlc5
check the tranny fluid level before you go.. and when was the fluid last changed..? Low fluid levels may be contributing to that noise?
Old 12-29-2016, 09:34 AM   #7
lmchu
Fluid Level Ok changed fluid 50k ago, I went for another opinion and they said wheel bearing.
Old 12-29-2016, 10:19 AM   #8
lord_varon
lord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of lightlord_varon is a glorious beacon of light
lord_varon's Avatar
2008 VUE 3.6L
Imchu,
Time for a trans fluid drain and fill...
And I just did a wheel bearing on the right side. That one was easy... When I go to do left side... that could be less fun as it has never been done as far as I know.... and I have had my car for over 3 years...
aka
Lord_Varon
07 Vue V6 AWD LOADED!!! aka SUPER CRITTER!!! Sadly gone, and definitely missed.
08 Equinox Sport 3.6 6 spd auto, AWD, even more loaded. And the jury is still out on it.
lord_varon is offline   Reply With Quote
Old 12-29-2016, 12:46 PM   #9
Amzonow232012
Amzonow232012 is on a distinguished road
I've got a very large inventory of Saturn Parts all Brand New OEM if you need any just send me a message. Good Luck!
Amzonow232012 is offline   Reply With Quote
Old 01-06-2017, 12:13 PM   #10
lmchu
Happy Re: 2005 Vue FWD 3.5 bearing noise
Update: Both front wheel bearings were worn, changed them out with Timkens.
I don't know what original manufacturers that came out but served me well for 216k miles. One rear wheel still has original bearing, I'll keep an ear out.
Thanks to all for the tips.
Old 01-16-2017, 05:31 PM   #11
fd1979
fd1979 is on a distinguished road
215k on your wheel bearings!!!!!! I replaced four on my 04 vue within 75k miles, traded in that car! First time I had to work on a wheel bearing in 45 years, go figure.
fd1979 is offline   Reply With Quote
Stubborn wheel bearing hub assembly 2005 Vue, help! tkearsey Vue General 50 04-26-2019 11:02 PM
2005 VUE RMD,ABS,Hub,Bearing, Sensor??? sixball Vue Tech 20 12-14-2013 04:18 PM
Help please, bearing noise...but not bearing problem at all!! Satillac S-Series General 18 09-01-2013 03:56 AM
2005 Saturn Ion Front Wheel Bearing???? JLD332 Ion General 7 07-19-2012 07:46 PM
2005 2.2L 5sp FWD VUE: Wheel Bearing Problem? OttawaBlackVue Vue Tech 1 05-08-2012 11:37 AM
