Old 11-18-2014, 11:47 AM   #1
ZKdawg
ZKdawg is on a distinguished road
ZKdawg's Avatar
2004 ION-2 Quad Coupe
Question wipers not working at all
my wipers stopped working, i tried to use them the other day and now they wont work.
i checked the fuses and relays with no success.
help plz
9-24-14
This is the day i finished the af23 QC tranny swap... yeah
9-25-14
It ran like a beauty
ZKdawg is offline   Reply With Quote
Old 11-18-2014, 12:03 PM   #2
billysvue
Default Re: wipers not working at all
I see you're in FL, so I doubt you burned out the motor because the wipers were iced to the windshield- or were they?
Look at the harness connectors to the motor?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Old 11-18-2014, 12:14 PM   #3
ZKdawg
ZKdawg's Avatar
I'm not getting anything from the motor, no sound, nothing.
It's not the relay, or the fuses.
It worked and now it doesn't.
9-24-14
9-25-14
Old 11-18-2014, 05:19 PM   #4
Dutchman1954
Dutchman1954 is on a distinguished road
Which leaves the wiring, or the switch on the steering column. Need a VOM to trace out the line from the fuse to the switch and from the switch to the motor.
Dutchman1954 is offline   Reply With Quote
Old 11-18-2014, 05:19 PM   #5
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
Check under the windshield cowel for the motor and linkage.
take the cowel off (few tabs and screws, and a lot of wiggling to get it off), the flip on the wiprers to see if you see any movement (linkage doing its work, or a tiny arm spinning in circles on the motor itself.
If nothing at all, since fuses and relays are good, might be a burnt motor.
03 ion-2 Sedan 5sp
♕KCCO
Old 11-18-2014, 05:40 PM   #6
2006 ion2
2007 ION-2 Sedan
No, take the cowl off and if it does nothing check for voltage at the motor. If you have voltage you have a bad motor. If not check the wiring and the wiper stick
2007 Saturn Ion 2
2003 Chevrolet venture lt
Wipers Not Working addbhp S-Series Tech 8 03-24-2010 03:29 PM
WIpers not working firestomper25 Ion Tech 23 03-02-2009 11:20 PM
Wipers not Working Saturn sc2 S-Series General 1 01-12-2009 03:52 PM
Wipers not working in cold wicked055 L-Series Tech 1 10-30-2007 07:55 AM
Have your wipers stopped working? coolgreany Miscellaneous Tech 3 12-19-2002 09:58 AM
