Old 05-21-2014, 08:01 PM   #1
rickystarshine
rickystarshine has a spectacular aura aboutrickystarshine has a spectacular aura about
rickystarshine's Avatar
2005 ION-2 Sedan
Default 2007 Ion No-Start P0341
Hi, my friends 07 Ion died on his way into town today & when I got over to look at it, it would fire up for a split second then die, no passlock or security light staying on or flashing(it does come on when you first try to start the car then goes out, so I know the bulb is good.
I hooked up a code scanner & had no codes at first. I tried starting it a couple more times then scanned it again & got 0341 Camshaft Position sensor bank 1.
The car has 102,000 miles, recent plugs, it has spark & fuel to the injector rail.
I went & picked up a new CPS & changed out the one on the front of the engine & that did not help, so I switched it with the one on the back of the engine & that did help either.
Any suggestions would be awesome......
Thanks!
Rick
2005 ION 2 5 spd 202,155 miles
2001 SL1 Auto 298,252 miles
1997 Sl1 Auto 163,266 miles
rickystarshine is offline   Reply With Quote
Old 05-21-2014, 08:22 PM   #2
rickystarshine
2005 ION-2 Sedan
Default Re: 2007 Ion No-Start P0341
Nevermind, he was out of gas & the gauge showed 1/8 tank....we put in 2 gallons & now its good......
Ooops!
Old 05-22-2014, 06:09 AM   #3
Ha-ha, lol!? Thanks for sharing! Its always good to share a laugh at ourselves - keeps it human.
Old 05-24-2014, 02:03 PM   #4
Dutchman1954
Dutchman1954 is on a distinguished road
Ooops!
I'm not sure if it's set up the same as the 2005's, but the low fuel display should have appeared at approx an eighth tank
That's something that you have to watch, as it appears to be a common issue. Depending upon the car that usually means that you could have as much as two and a half gallons left or less than a full gallon.
Dutchman1954 is offline   Reply With Quote
2007 Ion-2 will not start Nawtee Ion General 7 06-29-2013 01:03 PM
P0341.. no start... flooded winnipegsaturn S-Series Tech 17 11-19-2012 11:25 PM
My 2007 Vue wont start. Cecropian Vue General 12 07-16-2010 12:32 PM
98 SL2 won't start (P0341) topshot S-Series Tech 10 01-29-2008 11:23 AM
2007 VUE RL-sluggish start. annjot Vue Red Line 18 01-18-2007 02:52 PM
