Old 04-21-2014, 09:11 PM   #1
kcrossley
kcrossley is on a distinguished road
2003 ION-3 Sedan
Default Ticking noise when first started?
Does the Saturn ION tend to make a ticking noise when it's first started (cold engine)?
kcrossley is offline   Reply With Quote
Old 04-21-2014, 09:32 PM   #2
snakes
snakes has a spectacular aura aboutsnakes has a spectacular aura about
snakes's Avatar
2005 ION-1 Sedan
Default Re: Ticking noise when first started?
I don't think this is normal . The only time my car did this was when I had a very weak battery(went to Thailand for 2 weeks in the dead of winter in January and no one warmed up my car while I was gone) . My battery was on its last juice and the alternator made a ticking sound prior to starting. Sorry I couldn't help much hopefully one of the guys on the forum can answer. Is the car running while ticking ? Or prior to turning the key over?
snakes is offline   Reply With Quote
Old 04-22-2014, 08:37 AM   #3
kcrossley
2003 ION-3 Sedan
No, this is not battery related. The ticking noise happens at startup and lasts for about 10 seconds. It's definitely coming from the engine. It tends to happen more often in the morning when the engine is cold.
Old 04-22-2014, 08:52 AM   #4
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
is your oil good? what grade are you using?
03 ion-2 Sedan 5sp
♕KCCO
Old 04-22-2014, 09:09 AM   #5
kcrossley
2003 ION-3 Sedan
Oil level is good. Not sure on the grade. AAA car care center handles the oil changes.
Old 04-22-2014, 10:42 AM   #6
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
When was the last change? if you can, contact them to see what grade oil they put in, or next time you go, make sure they are putting 5W30. Ions are not too happy with anything else.
03 ion-2 Sedan 5sp
♕KCCO
Old 04-22-2014, 12:42 PM   #7
Dutchman1954
Dutchman1954 is on a distinguished road
Yes, find out what grade oil they used. A lot of places use 10w40, especially if they are running a oil change special.
Dutchman1954 is offline   Reply With Quote
Old 04-22-2014, 01:02 PM   #8
kcrossley
2003 ION-3 Sedan
Thanks for the tip about the oil. I didn't know a heavier weight would have that kind of effect.
Old 04-24-2014, 09:45 AM   #9
kcrossley
2003 ION-3 Sedan
I just wanted to post a followup for others who may be experiencing the same problem. It turns out the ticking noise was actually an exhaust leak. For a car that's 10 years old, that's not surprising.
Old 04-24-2014, 01:41 PM   #10
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
glad its that and not something regarding the oil lol
The exhaust on the ions are relatively easy to replace, as its all pretty much bolt on.
03 ion-2 Sedan 5sp
♕KCCO
Old 04-24-2014, 02:44 PM   #11
kcrossley
2003 ION-3 Sedan
Do you have one you can recommend?
Old 04-24-2014, 06:01 PM   #12
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
cheapest is ebay, but you gotta be careful there as far as fitment.
if theres a salvage yard or pull apart nearby, you can check if there are any ions there, or if your lucky, ion redlines if you wanna add a bit of power with the larger exhaust.
03 ion-2 Sedan 5sp
♕KCCO
Old 04-24-2014, 06:04 PM   #13
kcrossley
2003 ION-3 Sedan
Yes, my mechanic hates doing exhaust work for that very reason.
Old 04-25-2014, 12:40 AM   #14
MeanGreen
MeanGreen is on a distinguished road
MeanGreen's Avatar
2004 ION-2 Sedan
You're right. Had the ticking noise for a while and found out the nearside passenger gasket material had a leak. Replace with an auto parts store gasket, not something off eBay or you'll be looking at this job again. Also if you do the manifold to downpipe gasket again don't skimp, I had to do that one twice because of cheapo gasket failure. The bolts to get the manifold off are a PITA but it is doable driveway work, just mind your hands!
2004 ION 2 Sedan
-Autozone short ram
-FE5 Suspension with Pedder springs
-4300k Hi-lo HID
-OPTX green underglow
-35% tint all around
-Kicker Audio all around
MeanGreen is offline   Reply With Quote
Old 04-25-2014, 02:12 AM   #15
kcrossley
2003 ION-3 Sedan
Great info. Thanks for the post and photos.
Old 04-25-2014, 09:03 AM   #16
kevin.st56
kevin.st56's Avatar
2003 ION-2 Sedan
ill be having my share of exhaust work soon lol i ordered an upgraded exhaust. bought a 2.4 manifold, and a catback. had problems finding a downpipe bec of the flange bolt patern that connects to the tailpipe. the catback i ordered has the 3 both flange, found on 03-04 ions. 05-07 have 2 bolt flanged. could not, for the life of me, find an 04 redline downpipe, since it has the 3 bolt, so im stuck with the stock 03 sedan downpipe for the time being, unless i feel like ordering a new one with the 2 bolt, and chop it off to weld a 3 both to it. i have the tools, but lack the want tos lol
03 ion-2 Sedan 5sp
♕KCCO
ticking noise goose737700 Vue Tech 3 10-12-2013 11:30 AM
Fan noise when started rattlebox S-Series General 5 09-27-2012 02:13 PM
strange noise started yesterday from right front slv01sc2 Miscellaneous Tech 6 02-17-2002 01:06 PM
$ cyl L-Car ticking noise. A FIX sattech Miscellaneous Tech 0 03-30-2001 10:09 PM
ticking noise? lowrider SL1 S-Series Tech 14 11-11-2000 12:52 PM
