Old 09-18-2011, 04:17 PM   #1
Red97sc2
Red97sc2 is on a distinguished road
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
Default I'm back, with a rattle I can't explain.
First, the car = 2001 SL2a 101,510 miles.
After the last oil change I noticed a rattle coming from the front passenger side of the car. I let it go thinking it was the mud splash shield being loose (since I changed the oil THAT way). Plus that side marker light is loose, so I thought it was shaking.
Well, I had some extra time today and I investigated it. Here's a video of it:
http://www.youtube.com/watch?v=mXWRa65y4N4
I have been thoroughly over the top and underneath the engine and I'm 99.9% sure the sound is coming from the oil pan.
Symptoms: While running the AC it always rattles at idle, either in PARK or DRIVE. No AC it rattles sometimes at idle in PARK or DRIVE. When I'm driving, both with and without AC running it's not there. After driving and getting stopped at a light or stop sign it rattles, moreso with the AC on and sometimes with it off.
Now just today I was backing out of a parking space. Without the AC on it rattled a little BEFORE I put it in REVERSE. While in REVERSE it rattled the whole time. Stopping to put it in DRIVE - rattle - in DRIVE and BEFORE I accelerate - rattle - accelerating = no rattle.
So, please watch the video and give me your thoughts. I have not been on here in a while due to the SL2 running so good and no MAJOR repairs needed. Also, I don't know if Wolfman is still here but if he is I'd appreciate his input, or some of the other mech's input.
Thanks in advance, Paul
2008 Dodge Grand Caravan.
2008 Nissan Altima
1970 Mercury Cougar: 351C, 4spd. Classic for shows.
2005 Subaru Impreza
2003 Grand Marquis
Red97sc2 is offline   Reply With Quote
Old 09-18-2011, 05:15 PM   #2
spud42
spud42 is on a distinguished road
Default Re: I'm back, with a rattle I can't explain.
search Saturn belt tensioner rattle
Then watch this
http://www.youtube.com/watch?v=Or0-0oG5Hsc
spud42 is offline   Reply With Quote
Old 09-18-2011, 05:48 PM   #3
racinginblood
racinginblood will become famous soon enough
racinginblood's Avatar
1998 SL1
hard to tell sounds like compressor bearing failure a good mechanics stethescope could find it top end maybe lower end wow could be timing chain noise
racinginblood is offline   Reply With Quote
Old 09-18-2011, 05:51 PM   #4
racinginblood
1998 SL1
block the tires pull handbrake put it in drive undder load and check it or get someone you trust put it in gear and chock the tires and step on the gas just enough to give it load then check
Old 09-18-2011, 05:53 PM   #5
racinginblood
1998 SL1
im sure something would have let go and gone south by now if it was lower end
Old 09-18-2011, 05:59 PM   #6
PlasticCarsRock
PlasticCarsRock is a jewel in the roughPlasticCarsRock is a jewel in the roughPlasticCarsRock is a jewel in the rough
PlasticCarsRock's Avatar
Then watch this
No time to watch the video, but from the description, it sounds exactly like the classic belt tensioner rattle. Induce the rattle, and watch the tensioner--you'll probably see it shaking in tune with the noise. Usually the answer is a shorter belt--two different sizes are available: 780 and 778. You need the 778 belt. If you already have it, you probably need a new tensioner (preferably OE). The noise is often worse under load (a/c on, and the car in drive, if it's an automatic). It may be better under high-idle (when cold).
PlasticCarsRock is offline   Reply With Quote
Old 09-18-2011, 06:08 PM   #7
Red97sc2
Red97sc2's Avatar
2001 SL2
2005 ION-2 Sedan
And the winner IS: PlasticCarsRock!!! I watched the tensioner and sure enough, it moved in time to the rattle.
CONGRATS!!!!
And A BIG THANKS to you. This is my daughters car and I thought I was going to have to ditch it......Thank God...
Thanks again, Paul
2008 Nissan Altima
2005 Subaru Impreza
2003 Grand Marquis
Tensioner rattle is back -- even with new AC Delco tensioner and belt! 2003MercMaraude S-Series Tech 18 10-15-2010 07:23 PM
oil filter drain back, top end rattle? brian3222 S-Series Tech 9 05-24-2009 01:28 AM
Can anyone explain this??? Gottofried S-Series Tech 19 08-13-2006 09:32 AM
Back seat rattle... Easy to fix? newkai S-Series Tech 3 11-19-2004 12:08 AM
Could someone explain this to me Whelan S-Series Mods 6 06-29-2001 10:19 AM
