Old 06-28-2011, 09:32 PM   #1
ShawnV
ShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the roughShawnV is a jewel in the rough
ShawnV's Avatar
Default P0506 and P0507 idling problems
I recently dropped a rebuilt engine into my 1996 SW2.
Directly after, I had high idling that seemed to be intermittent.
I swapped out sensors, throttle bodies and PCV hoses and each time the idle went away then came back.
I was driving down the highway today and I started getting a flashing SES (random misfire) and it came up with a 506 and 507. I had the 507 before as well.
Help!
shawn
ShawnV is offline   Reply With Quote
Old 06-28-2011, 10:29 PM   #2
Default Re: P0506 and P0507 idling problems
Sounds suspiciously like the IAC is not functioning properly. First part to change and inspect the wiring for damage.
Old 06-29-2011, 08:42 PM   #3
ShawnV
ShawnV's Avatar
I got out there today and checked out the connector. One of the pins was shoved deep back into the connector, so I tried to fish it out with a probe. I got it most of the way and the first test drive was promising!
shawn
Old 06-29-2011, 08:48 PM   #4
laser3kw
laser3kw will become famous soon enough
2000 SC1
I recently had a p0507 pop up. Same thing, higher idle and gph was up 5%
it was caused by bumping the starter a couple of times and slight back fire / cough / sneeze blew the vacuum lines loose from the purge solenoid.
laser3kw is offline   Reply With Quote
Old 06-29-2011, 10:12 PM   #5
shawn
Go chop a connector off of a dead Saturn and solder it on. The back comes off the connector and you can then pull the wire seal and push the connector back where it belongs. Have a replacement in hand first.
Old 06-30-2011, 12:55 AM   #6
ShawnV
ShawnV's Avatar
I do have a connector here off another engine, but I couldn't figure out how to open up the connector to expose the wires.
Old 06-30-2011, 01:53 AM   #7
IIRC the back comes off. I have the parts to make the connectors. I should just go look. They are a PITA to make up so they spend much time in their box. It is easier to just solder in another connector and shrink wrap the splice.
http://shop.ebay.com/i.html?_from=R4...All-Categories
http://shop.ebay.com/i.html?_nkw=met...nectors&_rdc=1
And the source. http://www.metripack.com/
You have weather pac and metri pac connector systems, they function the same way but the max current is higher with the metri pac system. Both as shown on the 3rd link above. the eBay links are just so you can get an idea of the price of them.
Idling problems Meanie S-Series General 12 02-03-2009 10:17 PM
Idling problems ctrow S-Series Tech 3 05-07-2008 05:50 PM
idling problems CMSchops S-Series Tech 4 10-17-2006 11:33 AM
idling problems CMSchops S-Series Tech 11 09-28-2006 09:30 AM
idling problems CMSchops General Saturn Discussion 1 09-26-2006 03:16 PM
