Old 06-17-2011, 08:38 AM   #1
Meowth
Meowth is on a distinguished road
Meowth's Avatar
Default 2002 SC2 Automatic To Manual Transmission Conversion
So I was reading the page on Different Racing about what parts I need to do automatic to manual transmission conversion. To get to the point, if I purchased a 92-02 S-series with a manual transmission, would I be able to just swap all the parts into my current car?
Meowth is offline   Reply With Quote
Old 06-17-2011, 10:18 AM   #2
Low Saturn
Low Saturn's Avatar
2007 AURA XR
Default Re: 2002 SC2 Automatic To Manual Transmission Conversion
Most. You wouldnt be able to use the shift boot and PCM. If you use the flywheel and hydrolic assembly, make sure you use a 1991-1999 clutch and pressure plate.
Also 1992 manual transmissions have a provision still cast into them for the 1991 mounting system. This cast in piece will have to be cut off to clear the front cross member on the cradle.
Mike
-1991 Turbo SL2.
11.809 @ 116.488 mph
www.differentracing.com
-2001 Chevrolet Suburban
-2007 Saturn Aura XR
Old 06-17-2011, 05:01 PM   #3
Meowth
Meowth's Avatar
Sounds great. I've been seeing some Saturns on craigslist that I want for parts and some have manual transmissions. I think I'm going to get one if I can.
Automatic to Manual Transmission Swap Adam Opel Astra General 6 06-22-2010 11:58 AM
Manual to Automatic Transmission Swap vincent S-Series Tech 4 01-17-2009 07:59 PM
2002 SL1 automatic to 2001 MANUAL ? Saturntrip L-Series Tech 1 01-24-2008 02:08 PM
2002 SL2 Automatic Transmission Problems leia99 S-Series Tech 4 12-11-2007 06:51 PM
Manual to automatic transmission mohave S-Series Tech 18 01-17-2006 02:11 PM
