Old 03-24-2020, 03:38 PM   #1
1996SL11.9L
1996SL11.9L's Avatar
2002 SL1
Default 2002 AC compressor question
I have what appears to be a leak at the back of my compressor where a round slotted adjustment seems to be.
It was green around the threads.
Any idea what this adjustment is for? And can a simple seal replacement fix it?
I think itís part of the variable displacement based on suction pressure.
1996SL11.9L is online now   Reply With Quote
Old 03-24-2020, 04:01 PM   #2
toggenburg
toggenburg's Avatar
Default Re: 2002 AC compressor question
I would believe you cannot repair that, just need to replace the compressor.
Old 03-24-2020, 05:23 PM   #3
DO NOT ADJUST IT!? No one ever thought these compressors would last beyond new car warranties. The large plug is also an adjustment, factory done and has a paper seal warning against tampering/adjustments. The paper seal has long ago fallen off, tempting anyone to make adjustments that fails. That calibration plug is never meant for casual diy adjustment. The sole O-ring leaks refrigerant, oil and dye after years of reliable ac use. There's only one repair that's well documented and successfully repaired without replacing it. Sealer does more damage than its worth. It doesn't work, period. The cans don't have a money back guarantee when it fails. That's a hint there to stay away from ac sealers. Once used and ac still leaks, the repairs become monumental as the entire system will need to be disassembled to flush out sealer contaminating and sealing in the wrong places. Anyone using sealer effectively ruins their expensive-to-repair ac system.
Invisible refrigerant, oil and greenish yellow dye are in GM ac systems.
JerryHughes and his repair;
http://www.saturnfans.com/forums/sho...mpressor+leaks, Your choice to try a similar repair or replace it with associated costs of repairs.
Old 03-25-2020, 10:25 AM   #4
toggenburg
toggenburg's Avatar
Yikes! I did not know Jerry had success, he is not active anymore, but it seemed to work for him. I have learned something good here Fdryer, thanks.
Old 03-25-2020, 11:41 AM   #5
billr
I, too, have successfully fussed with that adjustment screw; but it ended up back where it was originally for best operation. So, I agree: leave it alone.
Those are not variable displacement compressors. They are fixed displacement with an inlet throttling valve. The throttling results in high/low pressures different than the "standard" for R134a.
Old 03-25-2020, 12:19 PM   #6
^ You are mistaken. Saturn uses variable displacement compressors. Search past threads for reprints I posted from GM service manuals. If interested, look in my photo album of a disassembled VDC (variable displacement compressor) donated to me from JerryHughes. If you can add any insight as to how the complicated mechanism in these VDCs vary displacement, please do. The snapshot of the copper bellows directly behind the large calibration screw on the rear of these compressors operates the same as mechanical pressure gauges and altimeters. The bellows moves linkages to vary displacement.
Old 03-25-2020, 03:22 PM   #7
billr
Perhaps I should have been more specific about the compressor I am referring to? The type I am familiar with is the Zexel model DCV-11A in my '94 SL2. It is not variable displacement. I tried to find an IPB so we could discuss the innards of the DCV-11A, but no joy so far.
Old 03-25-2020, 04:12 PM   #8
If your '94 uses a thermal expansion valve on the firewall where the two refrigerant lines are connected to the evaporator coil, your compressor is a variable displacement type unless compressor specs states a piston type. All Zexel compressors for Saturn are vane types. Vane compressors use the mechanics within itself to vary displacement.
Old 03-25-2020, 04:33 PM   #9
In addition to my previous reply, did you ask the experts on these forums? https://www.autoacforum.com/. One of several mvac sites capable of answering many vehicle ac questions.
Old 04-07-2020, 11:06 AM   #10
1996SL11.9L
2002 SL1
Iím going to pull a vacuum on it and see if it holds vacuum. If not I may remove it and replace the o-ring and put it back where it was.
2002 SL1 A/C Compressor Shawk S-Series General 4 07-19-2016 06:34 PM
1998 SL2 w/a 2002 ac compressor belt question dbbarney S-Series Tech 1 12-06-2012 04:08 PM
2002 SC2 A/C Compressor delphipgmr S-Series Tech 14 07-30-2012 04:55 PM
A/C Compressor out on 2002 SC1 jdguthrie S-Series Tech 13 07-19-2012 10:05 AM
2002 LW A/C Compressor Hot 64Pete L-Series Tech 2 08-16-2011 05:40 PM
