Old 10-04-2019, 12:43 PM   #1
bikeone43
bikeone43 is on a distinguished road
2009 VUE 2.4L
Default trans type
is the type l trans transmission the same or close to the 4t45e transmission the cd shows 4t40e and 4t45e on the same disc
bikeone43 is offline   Reply With Quote
Old 10-04-2019, 01:53 PM   #2
floridasl22002
Default Re: trans type
Your profile states you have a Vue. This is the L series forum. You will likely get the more accurate information by posting in the Vue Forum.
You may also find this link useful;
https://en.wikipedia.org/wiki/GM_4T40_transmission
Old 10-06-2019, 11:43 PM   #3
Dazed Re: trans type
floridasl22002 is, of course, correct and you would do well to re-start a thread in a VUE forum.
The 4T40E was built for lesser powered engines with lighter vehicle weight and the 4T45E for cars with more power and/or more weight. The differences between the two transmissions are internal. VUEs with GM engines were fitted with the 4T45E for several years.
Based on the cataloging I've viewed it appears that the 6T70 six speed transmission and the four speed 4T45E share the same bell housing to mate with the engine you have.
332,000 miles - Holy canolli!
A leftist, deep-stater will get the nomination for POTUS. What follows if he gets his way? A bad economy, weak military, increased terrorism and a greater RED CHINA.
What type of Trans fluid for 02 AWD? 02 Dawg Vue Tech 2 04-18-2015 03:21 PM
Oil Type to use romeroom S-Series Tech 20 07-03-2013 08:38 PM
can replace a type 2 valve body with a type 1?? twincharged S-Series General 0 02-05-2013 09:31 PM
S-Series Trans Fluid type??? dlacacres S-Series Tech 7 10-31-2009 12:15 PM
Oil Type Mustang46L General Saturn Discussion 16 01-21-2002 04:23 PM
